• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Member
    .NET-BroadcastEventWindow.1.0.5000.0.1:acad.exe - Application Error
    32 Views, 0 Replies
    08-22-2005 01:22 AM
    Hello All!
    I have a .NET dll which is a DBX wrapper wrrited by VC++7.0 and Vc++.NET.
    If I used (command"_.netload""my.dll") to load it.
    I get a memory cannot be read error (below) messagebox when I close the acad.exe.
    Title :.NET-BroadcastEventWindow.1.0.5000.0.1:acad.exe - Application Error
    Text:The instruction at "0x091462c0" referenced memory as "0x00000000". The memory could not be "read". Click on OK to terminate the program.
    But if I use the "netload" command in the command line,everything is ok.
    It is a wonder,even if i used the (command"_.netload""my.dll") ,close acad.exe is normal as long as I run "netload" command in command line once.
    Thanks!
    Please use plain text.
