My first .NET code with lots of errors, please need help.
Message 1 of 23
Hi everyone,
I am having a difficult time understanding the errors that the .NET API is giving me. When I run my first code:
'---code--------------------------------------
Imports Autodesk.AutoCAD.Runtime
Public Class vbstudentClass
' Define command 'NewCmd1'
_
Public Sub NewCmd1()
MsgBox("NewCmd1")
' Type your code here
End Sub
End Class
'----Immediate Window--------------------------------------
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='NaN' BindingExpression:Path=Source.MinimumWidth; DataItem='ToolBarControl' (Name=''); target element is 'ToolBarControl' (Name=''); target property is 'MinWidth' (type 'Double')
System.Windows.Data Error: 39 : BindingExpression path error: 'BackgroundOpacity' property not found on 'object' ''ContentPresenter' (Name='PART_CustomizeButtonInMainPanel')'. BindingExpression:Path=BackgroundOpacity; DataItem='ContentPresenter' (Name='PART_CustomizeButtonInMainPanel'); target element is 'SystemDropShadowChrome' (Name='Shdw'); target property is 'Opacity' (type 'Double')
System.Windows.Data Error: 39 : BindingExpression path error: 'Current' property not found on 'object' ''QuickAccessUndoControl' (HashCode=32115247)'. BindingExpression:Path=Current; DataItem='QuickAccessUndoControl' (HashCode=32115247); target element is 'ContentPresenter' (Name=''); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 39 : BindingExpression path error: 'Current' property not found on 'object' ''QuickAccessRedoControl' (HashCode=6503226)'. BindingExpression:Path=Current; DataItem='QuickAccessRedoControl' (HashCode=6503226); target element is 'ContentPresenter' (Name=''); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='NaN' BindingExpression:Path=Source.MinimumWidth; DataItem='InfoToolbar' (Name='InfoCenter'); target element is 'InfoToolbar' (Name='InfoCenter'); target property is 'MinWidth' (type 'Double')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'ElementName=mToggleButton'. BindingExpression:(no path); DataItem=null; target element is 'RibbonItemControl' (Name=''); target property is 'KeyTipPlacementTarget' (type 'UIElement')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'ElementName=mToggleButton'. BindingExpression:(no path); DataItem=null; target element is 'RibbonItemControl' (Name=''); target property is 'KeyTipActivationTarget' (type 'UIElement')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'ElementName=mText'. BindingExpression:(no path); DataItem=null; target element is 'RibbonItemControl' (Name=''); target property is 'KeyTipPlacementTarget' (type 'UIElement')
System.Windows.Data Error: 2 : Cannot find governing FrameworkElement or FrameworkContentElement for target element. BindingExpression:Path=BackgroundBorderColor; DataItem=null; target element is 'SolidColorBrush' (HashCode=5425146); target property is 'Color' (type 'Color')
Thank you,
-Jay
Replies (22)
Message 21 of 23
Alfred.NESWADBA
ok, when i start AutoCAD from VS (project in debug-mode), then within AutoCAD I start _NETLOAD and point to youir DLL, the command "helloworld" can be started fine.
The only thing I would change is you set Framework to version 3.5, as long as you want to run this app with AutoCAD 2012 you should use 4.0 instead. But that is only necessary for debug-reasons (to get breakpoints and so on).
>> but the actual demand loaded command
First: do you agree that your code runs fine when using NETLOAD to load your DLL and then start the command?
If so the problem is not the project or code itsself, it's demand-loading then? What have you done to get this project demand loaded? Played with the plugin-directory or manually set some registry stuff?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 22 of 23
Alfred, you are indeed correct in that the program works when I produce a compiled .dll, and load it with _netload.
I actually haven't done anything to my registry settings whatsoever.  The computer I'm working on is a new build (only two weeks old) that I specifically re-initialized so that I could get all of these tools working.  So I'm a bit mystified as to what is causing this problem.  That being said, I'm using a company specific instance of AutoCAD Map, so the only thing I can think is that there is something within that configuration that is causing the problem.  But even then, it should have affected the Plant3D instance.  That is, actually, a raw installation with no configuration loaded whatsoever.  So... hmm... don't know.
But as long as the .dll actually works, the question is, do I care?  I can still use it to load the the application, and then just _netload the dll when required.  So it might be just something I put on the back-burner until I have another idea.
Thanks for the help.
Message 23 of 23
Alfred.NESWADBA
so the number of debug-messages you receive from AutoCAD is not your problem ... and should not be your's, it's a problem Autodesk and/or Microsoft should check (and resolve).
Also your code runs fine after you did load your DLL with command _NETLOAD. So everything seems to be as designed.
Last point I see now is you want to have your tool automatically loaded when your AutoCAD starts.
Three options I read about it:
HTH, - alfred -
Alfred NESWADBA
