Multiple Viewports in Layout
GeeHaa
GeeHaa
I wrote a program to separate drawings with multiple layouts into several drawings. The problem I'm running into is even though there is only one viewport in the layout.the program is finding two. One has the right viewcenter, width and height the other is wrong. Is there any way to tell which one is the right one.
Thanks in Advance
Alexander.Rivilis
From ObjectArx Managed Docs:
Layout.GetViewports Method
This function returns a collection of ObjectIds of all the
Viewports that exist in the Layout's paperspace.
The first ID in the list will be the paperspace viewport.
If the list returned is empty, then this Layout has never been
switched to (activated).
The list is updated each time a layout is activated,
and kept up-to-date while that layout is active
whenever viewports are added or deleted).
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
