.NET
Distinguished Contributor
Message 1 of 4 (172 Views)
Multiline Attributes Revert to Single Line
172 Views, 3 Replies
11-12-2013 11:07 AM
There was a discussion about this issue in the past, but there was not a clear response.  I am experiencing this issue every now and then and I don't know why or how it happens.  No modifications to the BlockDefinitions or any BlockReferences are made and for some magic all multiline attributes in the drawing file revert to single line.  After that happens the only way I know to fix them is to go through all definitions in the Block Attribute Manager and make every attribute multiline again.  This is very annoying because I don't know how it happens so it can be prevented and because it takes time to fix them again.  AutoCAD 2012 vanilla, (Mechanical) on Windows 7 32 and 64 bits.  Does anybody know what causes this issue or have any suggestions about preventing this.  Any help will be greatly appreciated.
Member
Message 2 of 4 (122 Views)
Re: Multiline Attributes Revert to Single Line
12-02-2013 01:13 PM in reply to: HJohn1
Good evening,
I ran into the same problem in AutoCAD Architecture 2013.
1) How are you is a created multiline attribute?
2) How are you is save this drawing?
In my case I incorrect to save drawing.
Сorrected by this method:   "acDoc.Database.CloseInput(true)";
Document acDoc = Application.DocumentManager.MdiActiveDocument;
            string strDwgName = acDoc.Name;
            acDoc.Database.CloseInput(true);
            acDoc.Database.SaveAs(strDwgName, true, DwgVersion.Current, acDoc.Database.SecurityParameters);
Valued Contributor
FRFR1426
Message 3 of 4 (96 Views)
12-18-2013 01:34 AM in reply to: Sfinks7s
Same problem here on AutoCAD 2014 (I.18.0.0). The code to reproduce:
[CommandMethod("DBSAVEAS", CommandFlags.Session)]
public void DbSaveAs()
    Document doc = Application.DocumentManager.Open(Path.Combine(Path.GetTempPath(), "dbsaveas.dwg"), false);
    Database db = doc.Database;
    db.SaveAs(db.Filename, true, db.OriginalFileVersion, db.SecurityParameters);
The dbsaveas.dwg is attached. It contains one block insert with a multiline attibute called title. When I launch the command above and I reopen the drawing, the multiline flag is lost on the attribute and the second line of the value disappear.
Tried with CloseInput:
[CommandMethod("DBSAVEASCI", CommandFlags.Session)]
public void DbSaveAsWithCloseInput()
    db.CloseInput(true);
Doesn't work. The multiline attribute revert to a single line.
Tried with AcadDocument.Save (COM):
[CommandMethod("COMSAVE", CommandFlags.Session)]
public void ComSave()
    dynamic acadDoc = doc.GetAcadDocument();
    acadDoc.Save();
It works.
Tried with a side database:
[CommandMethod("SIDEDB", CommandFlags.Session)]
public void SideDb()
    using (var db = new Database(false, true))
        db.ReadDwgFile(Path.Combine(Path.GetTempPath(), "dbsaveas.dwg"), FileOpenMode.OpenForReadAndReadShare, true, null);
It works.
This is a really annoying bug, as it causes data lost. And I don't understand why there is no Document.Save in the .NET API (there is one in COM ???).
The problem also occurs with doc.DowngradeDocOpen(true)
Message 4 of 4 (61 Views)
12-20-2013 06:38 AM in reply to: FRFR1426
I still dealing with this issue in AutoCAD 2012However, I was hopping that when we upgrade to 2014 next year, this issue will be gone but I now see that it still there.  I am not using any of the method you mentioned. I am using the following methods.
Autodesk.AutoCAD.ApplicationServices.DocumentExtension.CloseAndSave()
Autodesk.AutoCAD.ApplicationServices.DocumentExtension.CloseAndDiscard()
Reverting back to single line not always occurs and I have not been able to figure out when or how it happens.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
