Multileader scale
Multileader scale
BrentBurgess1980
Message 1 of 11
Multileader scale
BrentBurgess1980
Does anyone know how to set the overall scale of a multileader? I have set the .Scale property, but that seems to have done nothing.
                MleaderStyle.Annotative = AnnotativeStates.False
                MleaderStyle.LeaderLineType = LeaderType.StraightLeader
                MleaderStyle.ArrowSize = Me.ArrowHeadSize
                MleaderStyle.BreakSize = Me.DimensionBreak
                MleaderStyle.DoglegLength = Me.LandingLength
                MleaderStyle.EnableLanding = True
                MleaderStyle.EnableDogleg = True
                MleaderStyle.EnableFrameText = False
                MleaderStyle.LandingGap = 2
                MleaderStyle.MaxLeaderSegmentsPoints = 50
                MleaderStyle.DrawMLeaderOrderType = DrawMLeaderOrderType.DrawLeaderFirst
                MleaderStyle.LeaderLineColor = Me.LeaderColour
                '' Text Settings
                MleaderStyle.ContentType = Autodesk.AutoCAD.DatabaseServices.ContentType.MTextContent
                MleaderStyle.TextHeight = 2.5
                MleaderStyle.TextAlignAlwaysLeft = True
                MleaderStyle.TextAttachmentType = TextAttachmentType.AttachmentMiddleOfTop
                MleaderStyle.TextAlignmentType = TextAlignmentType.LeftAlignment
                MleaderStyle.TextColor = Color.FromColorIndex(ColorMethod.ByPen, CShort(Project.DimensionTextColour))
                MleaderStyle.Scale = 50
                MleaderStyle.PostMLeaderStyleToDb(db, "50m")
                tr.AddNewlyCreatedDBObject(MleaderStyle, True)
Everything else works, but the overall scale is always 1.
Replies (10)
Message 2 of 11
Is your code changing an actual instance of a MleaderStyle?
Something Like?
MLeaderStyle mlStyle = dbentry.GetObject(OpenMode.ForWrite) as MLeaderStyle;
mlStyle.Scale = 20;
Message 3 of 11
BrentBurgess1980
Yeah I am trying to create a multileader style and set the scale to 50. I might try creating it and the getting it from the DB and changing the scale.
Message 4 of 11
BrentBurgess1980
That didnt seem to work either. Do you know if there is any documentation on MLeaders?
Message 5 of 11
Instead of setting the properties I copied from standard stlye and change the scale factor
Creates a new style named "newStyle"
  <CommandMethod("CreateMleaderStyle")> _
        Public Sub CreateMleaderStyle()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trx As Transaction = db.TransactionManager.StartTransaction()
                Dim mldrStyleDictionary As DBDictionary = db.MLeaderStyleDictionaryId.GetObject(OpenMode.ForWrite)
                Dim copyMleaderstyle As MLeaderStyle = mldrStyleDictionary.GetAt("Standard").GetObject(OpenMode.ForWrite)
                Dim newMleaderstyle As New MLeaderStyle()
                mldrStyleDictionary.SetAt("newStyle", newMleaderstyle)
                newMleaderstyle.CopyFrom(copyMleaderstyle)
                newMleaderstyle.Scale = 50
                trx.AddNewlyCreatedDBObject(newMleaderstyle, True)
                trx.Commit()
            End Using
        End Sub
Message 6 of 11
BrentBurgess1980
I have tried the code, and an interesting thig happens. In the MultiLeaderStyle dialog box, the scale is showing 50 - just what I want, but when I draw the MLeader and select it, the overall scale is 1.
Message 7 of 11
To change the scale of the actual mleader mleader I do not think there is a way .Net with exception of PInvoke.
see http://www.theswamp.org/index.php?topic=31861.msg386494#msg386494
The scale the code is setting is for style which should effect all mleaders on that style, but for indivdual mleaders scale property see link.
If that helps at all are if that is what you are after.
Message 8 of 11
BrentBurgess1980
Thats excellent!! now it is showing the scale I want.
Message 9 of 11
Dear Sir,
I have the same issue. Could you please show me how to do it in C#? Thanks!
Message 10 of 11
Jeff_M
@Anonymous wrote:
Dear Sir,
The link in the post 2 above yours which takes you to the Swamp has the C# solution.
Jeff_M, also a frequent Swamper
Message 11 of 11
Thanks!
