.NET
Multileader Jig
2 REPLIES 2
SRSDS
585 Views, 2 Replies
Multileader Jig
Hi all,
I'm trying to create a multileader jig. One with a single leader line but behaves like a multileader when inserted (ie. the text gets flipped depending on the orientation to the leader origin. I've drawn from Kean's example which had multiple vertices and code I found for manual addition without a jig.
For some reason the inserted jig leader won't flip the text. It has an additional hidden vertex point that you can see when you drag the text grip. Even though the style has .MaxLeaderSegmentsPoints = 2
Stumped. Attached is the manual example that inserts a leader between 0,0 and 10,10 and the faulty jig.
Does anyone have a simpler example or can pinpoint the problem?
2 REPLIES 2
SRSDS
in reply to: SRSDS
Sorry..it's not the text that doesn't flip. It's the leader start point from the text. (DogLeg vector).
It works correctly during the jig but not after insertion.
SRSDS
in reply to: SRSDS
I ended up not commiting the jig and inserting a new leader with properties from the jig.
”Boost
