.NET
Multi Sheet Plotting issue c#
4 REPLIES 4
1621 Views, 4 Replies
hi,
i tried the code from a blog, but i get an error at the line
pe.BeginPage(ppi, pi, (numSheet == layoutsToPlot.Count),  null);
the first layouts is okay, but at the following layouts there occurs the error eInvalidPlotInfo.
what is wrong there?
  [CommandMethod("mplot")]
    static public void MultiSheetPlot()
      Document doc =
        Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      Database db = doc.Database;
      Transaction tr =
        db.TransactionManager.StartTransaction();
      using (tr)
        BlockTable bt =
          (BlockTable)tr.GetObject(
            db.BlockTableId,
            OpenMode.ForRead
        PlotInfo pi = new PlotInfo();
        PlotInfoValidator piv =
          new PlotInfoValidator();
        piv.MediaMatchingPolicy =
          MatchingPolicy.MatchEnabled;
        // A PlotEngine does the actual plotting
        // (can also create one for Preview)
        if (PlotFactory.ProcessPlotState ==
            ProcessPlotState.NotPlotting)
          PlotEngine pe =
            PlotFactory.CreatePublishEngine();
          using(pe)
            // Collect all the paperspace layouts
            // for plotting
            ObjectIdCollection layoutsToPlot =
              new ObjectIdCollection();
            foreach (ObjectId btrId in bt)
              BlockTableRecord btr =
                (BlockTableRecord)tr.GetObject(
                  btrId,
                  OpenMode.ForRead
              if (btr.IsLayout &&
                  btr.Name.ToUpper() !=
                    BlockTableRecord.ModelSpace.ToUpper())
                layoutsToPlot.Add(btrId);
           int numSheet = 1;
            // Create a Progress Dialog to provide info
            // and allow thej user to cancel
            PlotProgressDialog ppd =
              new PlotProgressDialog(
                false,
                layoutsToPlot.Count,
                true
            using (ppd)
              foreach (ObjectId btrId in layoutsToPlot)
                    btrId,
                    OpenMode.ForRead
                Layout lo =
                  (Layout)tr.GetObject(
                    btr.LayoutId,
                    OpenMode.ForRead
                // We need a PlotSettings object
                // based on the layout settings
                // which we then customize
                PlotSettings ps =
                  new PlotSettings(lo.ModelType);
                ps.CopyFrom(lo);
                // The PlotSettingsValidator helps
                // create a valid PlotSettings object
                PlotSettingsValidator psv =
                  PlotSettingsValidator.Current;
                // We'll plot the extents, centered and
                // scaled to fit
                psv.SetPlotType(
                  ps,
                Autodesk.AutoCAD.DatabaseServices.PlotType.Extents
                psv.SetUseStandardScale(ps, true);
                psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
                psv.SetPlotCentered(ps, true);
                // We'll use the standard DWFx PC3, as
                // this supports multiple sheets
               psv.SetPlotConfigurationName(ps, lo.PlotConfigurationName, lo.CanonicalMediaName);
                // We need a PlotInfo object
                // linked to the layout
                pi.Layout = btr.LayoutId;
                // Make the layout we're plotting current
                LayoutManager.Current.CurrentLayout =
                  lo.LayoutName;
                // We need to link the PlotInfo to the
                // PlotSettings and then validate it
                pi.OverrideSettings = ps;
                piv.Validate(pi);
                if (numSheet == 1)
                  ppd.set_PlotMsgString(
                    PlotMessageIndex.DialogTitle,
                    "Custom Plot Progress"
                    PlotMessageIndex.CancelJobButtonMessage,
                    "Cancel Job"
                    PlotMessageIndex.CancelSheetButtonMessage,
                    "Cancel Sheet"
                    PlotMessageIndex.SheetSetProgressCaption,
                    "Sheet Set Progress"
                    PlotMessageIndex.SheetProgressCaption,
                    "Sheet Progress"
                  ppd.LowerPlotProgressRange = 0;
                  ppd.UpperPlotProgressRange = 100;
                  ppd.PlotProgressPos = 0;
                  // Let's start the plot, at last
                  ppd.OnBeginPlot();
                  ppd.IsVisible = true;
                  pe.BeginPlot(ppd, null);
                  // We'll be plotting a single document
                  pe.BeginDocument(
                    pi,
                    doc.Name,
                    null,
                    1,
                    true, // Let's plot to file
                    "c:\\test-multi-sheet"
                // Which may contain multiple sheets
                ppd.StatusMsgString =
                  "Plotting " +
                  doc.Name.Substring(
                    doc.Name.LastIndexOf("\\") + 1
                  " - sheet " + numSheet.ToString() +
                  " of " + layoutsToPlot.Count.ToString();
                ppd.OnBeginSheet();
                ppd.LowerSheetProgressRange = 0;
                ppd.UpperSheetProgressRange = 100;
                ppd.SheetProgressPos = 0;
                PlotPageInfo ppi = new PlotPageInfo();
                pe.BeginPage(
                  ppi,
                  pi,
                  null
                pe.BeginGenerateGraphics(null);
                ppd.SheetProgressPos = 50;
                pe.EndGenerateGraphics(null);
                // Finish the sheet
                pe.EndPage(null);
                ppd.SheetProgressPos = 100;
                ppd.OnEndSheet();
                numSheet++;
              // Finish the document
              pe.EndDocument(null);
              // And finish the plot
              ppd.PlotProgressPos = 100;
              ppd.OnEndPlot();
              pe.EndPlot(null);
        else
          ed.WriteMessage(
            "\nAnother plot is in progress."
4 REPLIES 4
philippe.leefsma
Hi
Some of the reasons might be 1/ that when using this approach each layout needs to have the same paper size 2/ the layouts need to be fully initialized before plotting, which means they need to be opened visible at least once in AutoCAD.
I hope it helps.
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
www.autodesk.com/joinadn
Philippe Leefsma
Autodesk Developer Network
gpq
Hi.
I have also the same problem.If i set the same paper size all works fine ,but if i need different paper size don't work.
I have try with the command PUBLISH and here works also with different paper size.do you have solve it?
thanks
in reply to: gpq
I Am also having same problem. Any one got solution for this please help
norman.yuan
The reply from @philippe.leefsma has already explicitly stated that this code of printing multiple sheets only works when all layouts' sheet size are the same.
So, if the sheet sizes are different, you need to do repeat the code on each layout, one by one. Obviously, if you plot to PDF, you would get multiple PDF files instead of one PDF file with multiple pages. If you want to final result to be a single PDF file with multiple pages, you need to write extra code to "stitch" multiple PDF files into a multiple page PDF file, which is rather easy with many third party .NET PDF manipulating utililty/tool/library, such as iText (most popular open source for PDF manipulation). This is what I did with my PDF plotting app, and I guess/bet this is what AutoCAD's publishing does behind the scene.
Norman Yuan
Drive CAD With Code
”Boost
