.NET
Monitoring If the Text Edit Ribbon Tab Is Open
6 REPLIES 6
IvanShchitov
761 Views, 6 Replies
Greetings,
How can I make a module that detects wether the text editing tab is open or not?
Best regards,
Ivan
Tags (2)
6 REPLIES 6
You can track whenever the Tab is activated
For instance, from inside Initialize event
void IExtensionApplication.Initialize()
    Autodesk.Windows.RibbonControl ribCtrl = Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.RibbonControl;
    foreach(Autodesk.Windows.RibbonTab tab in ribCtrl.Tabs )
        if (!string.IsNullOrWhiteSpace(tab.Id) && tab.Id.Contains("ID_MText_Tab"))
            tab.Activated += tab_Activated;
void tab_Activated(object sender, EventArgs e)
    // do something here...
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Thank you very much, Augusto!
This code is for C++, isn't it? How to do the same in Visual Basic 2010?
Actually is a C# code, and you can convert to VB.NET at http://www.developerfusion.com/tools/convert/csharp-to-vb/
Augusto Goncalves
Thank you, Augusto!
Greetings, Augusto!
I've inserted your code in Microsoft Visual C# 2010 Express and it showed me three errors, particularly:
01. 'CSharp_Plugin.DetectingTab.IExtensionApplication.Initialize()': containing type does not implement interface 'Autodesk.AutoCAD.Runtime.IExtensionApplication'
02. The type or namespace name 'Windows' does not exist in the namespace 'Autodesk' (are you missing an assembly reference?)
03. The type or namespace name 'Ribbon' does not exist in the namespace 'Autodesk.AutoCAD' (are you missing an assembly reference?)
How can I fix these errors?
Best regards,
Ivan
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
namespace CSharp_Plugin
    public class DetectingTab
            foreach (Autodesk.Windows.RibbonTab tab in ribCtrl.Tabs)
”Boost
