.NET
matus.brlit
Message 1 of 9 (503 Views)
Modeless window always on top
503 Views, 8 Replies
01-17-2012 03:11 AM
I have a problem with modeless window. It stays on top even when it loses focus.
This is how I show the form:
            Dim myForm As New myFormClass
            Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(formOwner, myForm)
Any ideas? TopMost property is set to False.
Active Contributor
cincir
Message 2 of 9 (486 Views)
Re: Modeless window always on top
01-17-2012 10:56 AM in reply to: matus.brlit
I think that is because you are using the ShowModelessDialog function and autocad threats your form as it is a paletteset. because you know palettesets are modeless windows but they are always on top. i advise you to use Form instances Hide method in forms lost focus event.
matus.brlit
Message 3 of 9 (472 Views)
01-17-2012 10:45 PM in reply to: cincir
but that's not the behavior i want, the modeless window is the Help window and i want the user to be able to have the help shown and work with the program, be able to swithch to help and back.
the minimize works, but it's not that comfortable
Active Contributor
cincir
Message 4 of 9 (455 Views)
01-18-2012 08:14 AM in reply to: matus.brlit
Does making help window autohide solve your problem? You can create a paletteset instead of a form and make the paletteset autohide.
if not try Form.Show() instead of Application.ShowModelessDialog().
matus.brlit
Message 5 of 9 (440 Views)
01-18-2012 11:07 PM in reply to: cincir
i tried Form.Show with the same result, i guess I'm doing something fundamentally wrong, or it's AutoCAD that's causing the problem
but I'm more inclined to blame AutoCAD, because when I make a winform application, it works fine
Active Contributor
cincir
Message 6 of 9 (428 Views)
01-19-2012 11:02 AM in reply to: matus.brlit
Which autocad are you using? I tested Form.Show in Autocad2012 and it works.
matus.brlit
Message 7 of 9 (424 Views)
01-19-2012 11:26 PM in reply to: cincir
i'm using Civil 2012, but i run it as clean AutoCAD
did you use AcApp.ShowModalDialog for the main window, or did you use Form.ShowDialog ?
Active Contributor
cincir
Message 8 of 9 (422 Views)
01-20-2012 12:09 AM in reply to: matus.brlit
I used Form.Show() not Form.ShowDialog() . i thought that you want a modeless form.
matus.brlit
Message 9 of 9 (419 Views)
01-20-2012 12:19 AM in reply to: cincir
I am opening the modeless form from a modal form
form1 has a button (or responds to keypress event)  that opens form2, form1 is modal, form2 is modeless
