.NET
Active Member
allentable
Message 1 of 7 (332 Views)
MlineStyle
332 Views, 6 Replies
05-27-2013 12:18 AM
I want to use MlineStyle to custom mLine.
Here are my own codes and it does't work.
Line dashdot = new Line();
dashdot.Linetype = "Dash";
MlineStyleElement off1100 = new MlineStyleElement(3720 / 2, Autodesk.AutoCAD.Colors.Color.FromRgb(0, 0, 0), dashdot.LinetypeId);
MlineStyle mlineStyle = new MlineStyle();
mlineStyle.Elements.Add(off1100, false);
Mline ml = new Mline();
ml.Style = mlineStyle.ObjectId;
How can I use MlineStyle?
Thanks in advance.
Allen
Active Member
allentable
Message 2 of 7 (311 Views)
Re: MlineStyle
05-27-2013 06:27 PM in reply to: allentable
       [CommandMethod ("mil")]
        public void MLINECREATE()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                DBDictionary mlineDic =(DBDictionary)tr.GetObject(db.MLStyleDictionaryId,OpenMode.ForRead);
                if (!mlineDic.Contains("TEST"))
                    mlineDic.UpgradeOpen();
                    mlineDic.SetAt("TEST", mlineStyle);
                    tr.AddNewlyCreatedDBObject(mlineStyle, true);
                    mlineStyle.EndAngle = 3.14159 * 0.5;
                    mlineStyle.StartAngle = 3.14159 * 0.5;
                    mlineStyle.Name = "TEST";
                    MlineStyleElement off1100 = new MlineStyleElement(10 / 2, Autodesk.AutoCAD.Colors.Color.FromRgb(255, 0, 0), db.Celtype);
                    mlineStyle.Elements.Add(off1100, true );
                    MlineStyleElement off0 = new MlineStyleElement(0, Autodesk.AutoCAD.Colors.Color.FromRgb(255, 255,255), db.Celtype);
                    mlineStyle.Elements.Add(off0, true );
                    MlineStyleElement off1100n = new MlineStyleElement(-10 / 2, Autodesk.AutoCAD.Colors.Color.FromRgb(255,255, 0), db.Celtype);
                    mlineStyle.Elements.Add(off1100n, true );
                    mlineStyle.ShowMiters = false;
                    ml.Style =mlineStyle .ObjectId;
                    //ml.Style = db.CmlstyleID;
                    ml.Normal = Vector3d.ZAxis;
                    ml.Justification = MlineJustification.Zero;
                    ml.AppendSegment(new Point3d(0, 0, 0));
                    ml.AppendSegment(new Point3d(100, 0, 0));
                    ml.AppendSegment(new Point3d(100, 80, 0));
                    ml.AppendSegment(new Point3d(0, 80, 0));
                    ml.IsClosed =false ;
                    btr.AppendEntity(ml);
                    tr.AddNewlyCreatedDBObject(ml, true);
                tr.Commit();
            doc.SendStringToExecute("_ZOOM _Ob _L  ",true,false,false);
The code  (mainly supplied by Hallex, Thanks again) can work , but when I open the menu [options]-[mlinestyle]  and CLICK the "TEST" in the STYLE list,the autocad application occurs an error and closed. I don't know the reason.
Any help will be appreciated.
Allen
*Expert Elite*
Hallex
Message 3 of 7 (292 Views)
Re: MlineStyle
05-28-2013 06:56 AM in reply to: allentable
Try remove this line from code:
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
*Expert Elite*
Hallex
Message 4 of 7 (286 Views)
Re: MlineStyle
05-28-2013 07:46 AM in reply to: allentable
I've added small changes, this code working on my A2010,
see if this helps
        [CommandMethod("mil")]
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                doc.TransactionManager.EnableGraphicsFlush(true);
                DBDictionary mlineDic = (DBDictionary)tr.GetObject(db.MLStyleDictionaryId, OpenMode.ForRead);
                    mlineStyle.Elements.Add(off1100, true);
                    MlineStyleElement off0 = new MlineStyleElement(0, Autodesk.AutoCAD.Colors.Color.FromRgb(255, 255, 255), db.Celtype);
                    mlineStyle.Elements.Add(off0, true);
                    MlineStyleElement off1100n = new MlineStyleElement(-10 / 2, Autodesk.AutoCAD.Colors.Color.FromRgb(255, 255, 0), db.Celtype);
                    mlineStyle.Elements.Add(off1100n, true);
                    mlineStyle.EndInnerArcs = false;
                    mlineStyle.EndSquareCap=false;
                    mlineStyle.EndRoundCap = false;
                    db.CmlstyleID = mlineStyle.ObjectId;
                    tr.TransactionManager.QueueForGraphicsFlush();
                    ml.IsClosed = true;
                doc.TransactionManager.FlushGraphics();
                tr.Commit();
           // doc.SendStringToExecute("_ZOOM _Ob _L  ", true, false, false);
Active Member
allentable
Message 5 of 7 (273 Views)
Re: MlineStyle
05-29-2013 05:43 AM in reply to: Hallex
Thanks, Hallex,
The codes really works, but when I open the menu [options]-[mlinestyle] to see the details.
The application shows errors again,
System.AccessViolationException: 尝试读取或写入受保护的内存。这通常指示其他内存已损坏。
   在 Autodesk.AutoCAD.DatabaseServices.DBObject.DeleteUnmanagedObject()
   在 Autodesk.AutoCAD.Runtime.DisposableWrapper.!DisposableWrapper()
   在 Autodesk.AutoCAD.Runtime.DisposableWrapper.Dispose(Boolean )
   在 Autodesk.AutoCAD.DatabaseServices.DBObject.Dispose(Boolean )
   在 Autodesk.AutoCAD.Runtime.DisposableWrapper.Dispose()
   在 Autodesk.AutoCAD.AcMultiLineUi.MlineStylePreviewControl.set_PreviewStyle(MlineStyle value)
   在 Autodesk.AutoCAD.AcMultiLineUi.MlineStyleForm.UpdateSelected()
   在 Autodesk.AutoCAD.AcMultiLineUi.MlineStyleForm.MlineStyleForm_Load(Object sender, EventArgs e)
   在 System.EventHandler.Invoke(Object sender, EventArgs e)
   在 System.Windows.Forms.Form.OnLoad(EventArgs e)
   在 System.Windows.Forms.Form.OnCreateControl()
   在 System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   在 System.Windows.Forms.Control.CreateControl()
   在 System.Windows.Forms.Control.WmShowWindow(Message& m)
   在 System.Windows.Forms.Control.WndProc(Message& m)
   在 System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   在 System.Windows.Forms.ContainerControl.WndProc(Message& m)
   在 System.Windows.Forms.Form.WmShowWindow(Message& m)
   在 System.Windows.Forms.Form.WndProc(Message& m)
   在 System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   在 System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   在 System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
translate into English:
attempt to read from or write into protected memory,this usually indicates other memory is broken.
Maybe something is wrong with my application.
If I didn't try to open it, this can be the whole solution.
Thanks again.
Best regards.
Allen
ADN Support Specialist
Balaji_Ram
Message 6 of 7 (250 Views)
Re: MlineStyle
06-07-2013 02:33 AM in reply to: allentable
Hi Allen,
I could reproduce the crash in AutoCAD 2013.
Please try including this line of code :
mlineStyle.Description = String.Empty;
It seems AutoCAD 2013 is more particular about setting this empty when there is no description text for the style.
Balaji
Developer Technical Services
Autodesk Developer Network
Active Member
allentable
Message 7 of 7 (225 Views)
Re: MlineStyle
06-12-2013 07:26 AM in reply to: Balaji_Ram
Hi Balaji_Ram,
This mlineStyle.Description = String.Empty; really solve the problem.
You are not logged in.
Announcements
Need installation help?
Ask the Community
