.NET
Active Contributor
chikito1990
Message 1 of 2 (341 Views)
Merging two cells in a row?
341 Views, 1 Replies
08-12-2013 03:15 AM
Hi all,
I am trying to merge two cells in one but i cannot find proper method to do that. Any suggestions?
Example:
I am creating a table with dynamic number of rows and columns:
 for (int i = 3; i < tbRight.NumRows; i++)
                    for (int j = 0; j < tbRight.NumColumns; j++)
                        if (num2 == numCircles - 1)
                            Cell c = new Cell(tbRight, i, j);
                            c.TextHeight = 450;
                            tbRight.SetTextString(i, j, (num2 + 1).ToString() + "# - " + rightConn[num2]);
                            num2++;
                        else if (num2 > numCircles - 1)
                        else
                            c.TextHeight = 450;
                            num2++;
 First row of the table is the header and i have two free rows with two columns each. I want to merge all of them to look like one row.
On the other hand, is it possible to align the text in the table in the middle and also the vertical align to be in the middle.
Thank you in advance!
Valued Mentor
gasty1001
Message 2 of 2 (304 Views)
Re: Merging two cells in a row?
08-12-2013 08:56 AM in reply to: chikito1990
You can merge cell ranges, like this:
Private Sub FormatCells(ByVal ft As Table, ByVal row As Integer, ByVal start As Integer, ByVal fend As Integer)
        Dim rc As CellRange = CellRange.Create(ft, row, start, row, fend)
        ft.MergeCells(rc)
    End Sub
Gaston Nunez
You are not logged in.
Ask the Community
