.NET
Message 1 of 6 (223 Views)
Memory Stream and XRecords
223 Views, 5 Replies
10-07-2013 11:43 PM
Hello everybody,
I try to serilize a class with a binaryserialization and attach it as an xrecord to an entity using the memory stream. But I get an error occurred, when I try to run my test1 command (Cannot convert from MemoryStream into Byte[] Array). Here's the code:
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Colors;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Diagnostics;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.Drawing;
using System.IO;
using Autodesk.AutoCAD.Windows;
using System.Runtime.Serialization.Formatters.Binary;
using System.Runtime.Serialization;
using System.Drawing.Imaging;
using Autodesk.Windows;
using System.Data;
using Autodesk.AutoCAD.ApplicationServices.Core;
[Serializable]
public enum DogColor
Brown,
Black,
Mottled
[Serializable]
public class Dog
public String Name
get;
set;
public DogColor Color
get;
set;
public override String ToString()
return String.Format("Dog: {0}/{1}", Name, Color);
[CommandMethod("TEST1")]
public void Test1()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
PromptEntityOptions peo = new PromptEntityOptions("\nSelect an entity: ");
peo.AllowNone = false;
PromptEntityResult per = ed.GetEntity(peo);
if (per.Status == PromptStatus.OK)
ObjectId id = per.ObjectId;
Dog myDog = new Dog();
myDog.Name = "Foo";
myDog.Color = DogColor.Brown;
ResultBuffer resbuf = new ResultBuffer();
MemoryStream memorystream = new MemoryStream();
BinaryFormatter bf = new BinaryFormatter();
bf.Serialize(memorystream, myDog);
resbuf.Add(new TypedValue((int)DxfCode.BinaryChunk, memorystream));
SetXrecord(id, "test", resbuf);
Message 2 of 6 (214 Views)
Re: Memory Stream and XRecords
10-08-2013 12:30 AM in reply to: NikWach
The MemoryStream has a method ToArray which converts it to a Byte[]...
So change your line to
resbuf.Add(new TypedValue((int)DxfCode.BinaryChunk, memorystream.ToArray()));
 And the error will go away.
Moderator
Alexander.Rivilis
Message 3 of 6 (207 Views)
10-08-2013 12:53 AM in reply to: NikWach
As far as I remember BinaryChunk length have to be less than 255. So you have to split binary.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Message 4 of 6 (195 Views)
10-08-2013 02:33 AM in reply to: Matti72
thx, it works
Message 5 of 6 (192 Views)
10-08-2013 02:35 AM in reply to: Alexander.Rivilis
I dont know, if it is really so.
I do the following changes:
string Mystring = "Lorem ipsum dolor sit ametor sit amet, consectetur adipiscing elit. Pellentesque quis tristique risus. Vivamus dignissim lacinia ante, eu pretium lacus congue eu. Pellentesque in pellentesque eros. Phasellus volutpat viverra erat vel ultrices. Praesent mattis metus.Lorem ipsum dolor sit ametor sit amet, consectetur adipiscing elit. Pellentesque quis tristique risus. Vivamus dignissim lacinia ante, eu pretium lacus congue eu. Pellentesque in pellentesque eros. Phasellus volutpat viverra erat vel ultrices. Praesent mattis metus.";
bf.Serialize(memorystream, Mystring);
Than I attach it, and it works.
I cannot get the byte array to be shown:
Autodesk.AutoCAD.ApplicationServices.Core.Application.ShowAlertDialog("The attached data is: " + memorystream.GetBuffer());
this code doesn't work.
How I have to do the splitting?
Message 6 of 6 (182 Views)
10-08-2013 02:59 AM in reply to: NikWach
If you serialize data you have to deserialize it, before you can use it again...
memorystream.Seek(0, System.IO.SeekOrigin.Begin);
string myStr = bf.Deserialize(memorystream) as string;
Autodesk.AutoCAD.ApplicationServices.Core.Application.ShowAlertDialog("The attached data is: " + myStr);
 edit:
In the line
you have (of course) to use the serialized class. So it is string in the example in your last post, in the example in your first post it would be
Dog myDog = bf.Deserialize(memorystream) as Dog;
And as always it would be a good idea to test the result, if it is null
You are not logged in.
Ask the Community
