I have an mleader with a single vertices point.
There's a thing called a doglength which enables a grip point that allows the leader to be repositioned.
Dim ml As MLeader = TryCast(Entity, MLeader) ml.SetDatabaseDefaults() m_leaderIndex = ml.AddLeader() m_leaderLineIndex = 0 ml.SetDoglegLength(m_leaderLineIndex, 2.5)
I have a problem with the dogleg length in that I can't rotate it according to the current UCS. Is this possible?
Solved by SRSDS. Go to Solution.
