.NET
Valued Contributor
Ertqwa
Message 1 of 5 (248 Views)
MLeader - landing - dogleg
248 Views, 4 Replies
06-23-2013 01:26 AM
Can anyone tell me what the difference is between the landing and a dogleg of a mleader? What is the difference between the properties:
EnableDogleg
DoglegLength
EnableLanding
LandingGap
Thank you.
ADN Support Specialist
fenton.webb
Message 2 of 5 (221 Views)
Re: MLeader - landing - dogleg
06-24-2013 10:07 AM in reply to: Ertqwa
If you draw an MLeader inside of AutoCAD, then enable the Properties window and select the MLeader you will easily see what all of these options do
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Valued Contributor
Ertqwa
Message 3 of 5 (211 Views)
06-24-2013 01:19 PM in reply to: fenton.webb
No it doesn't. The multileader does not have a property dogleg or dogleg length (in AutoCAD 2012).
But it turns out that the property 'Landing distance' (in AutoCAD) is the 'DogLegLength' (in .NET API), and 'EnableDogLeg' is the 'Horizontal Landing'. 'Landing gap' is for mleaders with text only. Which leaves 'EnableLanding'. What does this do? If I set it to FALSE (in .NET API), it still shows the landing gap for a mleader with text.
Documentation says "Boolean to enable/disable landing of leader line." But it doesn't affect horizontal landing or landing gap.
Ty for the reply.
Valued Mentor
jeff
Message 4 of 5 (203 Views)
06-24-2013 04:51 PM in reply to: Ertqwa
If I remember correctly and would have to dig it up, but certain properties had to be set in a certain order and/or would only work after the Mleader was added to the database.
You can also find your answers @ TheSwamp
Valued Contributor
Ertqwa
Message 5 of 5 (192 Views)
06-26-2013 09:51 PM in reply to: jeff
Ok, I'll keep that in mind. No luck so far.
Ty for the reply.
You are not logged in.
Announcements
Need installation help?
Ask the Community
