Can anyone tell me what the difference is between the landing and a dogleg of a mleader? What is the difference between the properties:
EnableDogleg
DoglegLength
EnableLanding
LandingGap
Thank you.
If you draw an MLeader inside of AutoCAD, then enable the Properties window and select the MLeader you will easily see what all of these options do
No it doesn't. The multileader does not have a property dogleg or dogleg length (in AutoCAD 2012).
But it turns out that the property 'Landing distance' (in AutoCAD) is the 'DogLegLength' (in .NET API), and 'EnableDogLeg' is the 'Horizontal Landing'. 'Landing gap' is for mleaders with text only. Which leaves 'EnableLanding'. What does this do? If I set it to FALSE (in .NET API), it still shows the landing gap for a mleader with text.
Documentation says "Boolean to enable/disable landing of leader line." But it doesn't affect horizontal landing or landing gap.
Ty for the reply.
