.NET
Valued Contributor
Message 1 of 4 (1,200 Views)
Accepted Solution
MDIActiveDocument and DocumentActivated
1200 Views, 3 Replies
09-21-2012 01:16 PM
I have set a handler for the DocumentActivated event message but it doesn't get called when I set the MDIActiveDocument on the document manager object. It gets called when I swich windows, but not when the active document is initially set. Any ideas?
[CommandMethod("IFX_NEW_ASSEMBLY", CommandFlags.Session)]
void NewAssembly()
     Document doc = Application.DocumentManagerr.Add("");
     Application.DocumentManager.MDIActiveDocument = doc;
Should the DocumentActivated event be fired with the above code. P.S. I am positive the event handler is hooked up correctly.
- Mike B
*Expert Elite*
Message 2 of 4 (1,188 Views)
Re: MDIActiveDocument and DocumentActivated
09-21-2012 02:31 PM in reply to: mbujak
How do you wire up the DocumentActivated event?
Following code works for me:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(DocumentActevatedEvent.MyCommands))]
[assembly: ExtensionApplication(typeof(DocumentActevatedEvent.MyCommands))]
namespace DocumentActevatedEvent
    public class MyCommands : IExtensionApplication
        #region IExtensionApplication Members
        public void Initialize()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            try
                ed.WriteMessage("\nInitializing...");
                Application.DocumentManager.DocumentActivated += DocumentManager_DocumentActivated;
                ed.WriteMessage("completed.");
            catch (System.Exception ex)
                ed.WriteMessage("failed:\n");
                ed.WriteMessage(ex.Message);
            Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        private void DocumentManager_DocumentActivated(object sender, DocumentCollectionEventArgs e)
            e.Document.Editor.WriteMessage("\n{0} activated.", e.Document.Name);
        public void Terminate()
        #endregion
        [CommandMethod("AddNewDoc", CommandFlags.Session)]
        public static void RunMyCommand()
            Document dwg = Application.DocumentManager.Add(null);
            Application.DocumentManager.MdiActiveDocument=dwg;
 I use AutoCAD 2012 and VS2010.
Actually, the second line of code in the CommandMethod:
Application.Documentmanager.MdiActiveDocument=dwg;
is not needed. When a new document is added, AutoCAD automatically set it as the active document. That is, the DocumentActivated event is triggered at the end of Add() method, not by the code App...MdiActiveDocument=dwg;
Valued Contributor
Message 3 of 4 (1,167 Views)
09-22-2012 06:52 AM in reply to: norman.yuan
No different than your code except I have an AppData class that manages custom DocData class collection. The AppData has an Initialization method where the wiring is done. This gets called by the extension class initialization.
I removed the assignment and it seems to fire now.
-Mike
New Member
Message 4 of 4 (968 Views)
03-13-2013 09:17 PM in reply to: norman.yuan
Is anyone else having this same dwg activate problem, with R2013? I have a large project that has stopped working since the 2013 upgrade.
I have substituted the new call DocumentCollectionExtension.Add(acDocMgr,templatefile) - and I am using CommandFlags.Session - but the document is still not activated until the command has finished.
I've distilled it down to a couple of simple test commands:
    <CommandMethod("NewDrawing", CommandFlags.Session)> _
    Public Sub NewDrawing()
        'Create a new drawing and activate it
        Dim strTemplatePath As String = "acad-test.dwt" 'from support path
        Dim acDocMgr As DocumentCollection = Application.DocumentManager
        Dim acDoc As Document = DocumentCollectionExtension.Add(acDocMgr, _
                                            strTemplatePath)
        'the above line should activate the new added document but doesn't
        'acDocMgr.MdiActiveDocument = acDoc  'THIS LINE DOES NOT MAKE THE DWG ACTIVE
        Application.ShowAlertDialog("Active document is now " & acDocMgr.MdiActiveDocument.Name)
        'this stills shows drawing1 until after the command finishes
    End Sub
    <CommandMethod("ActiveDrawing", CommandFlags.Session)> _
    Public Sub ActiveDrawing()
        'Show which drawing is currently active
        'this shows Drawing2 if this is run after the NewDrawing command has finished
    End Sub
Is there any updated sample code for 2013 anywhere? I could not get the code in the 2013 Dev Guide (here, search for "LockDoc") to compile as it has not been updated to use the new DocumentCollectionExtension methods. I have substituted the new method calls into that code but still have the activation problem.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
