.NET
Locating all jpg references
2 REPLIES 2
Lisa_Pohlmeyer
574 Views, 2 Replies
I searched the groups and the closest discussion I could find was here but there didn't seem to be a clear cut solution. http://forums.autodesk.com/t5/NET/How-to-programmatically-find-all-references-xref-dwg-jpg-pdf-OLE/m... I have a jpg file that I needed to apply some transparency to and saved it as a png file. I now want to delete the jpg file from the folder but it's being referenced in several drawings, and I don't know which ones. Is there a way to reverse the function of Reference Manager (perhaps with a different app), ie find all the drawing files that reference my jpg file?
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Tags (3)
2 REPLIES 2
I'd think that what you want is not the reverse of Xrefernce Manager, because now you need to find if an image file is referenced in multiple drawings, meaning AutoCAD must open/read all drawings in question (say, all drawing files in a folder) to find out if the image file is referenced in a drawing or not.
So, the first thing you need to do is to write code to identify if a drawing has RasterImageDef/RasterImage that refers to the source file. Then you can process all drawings in a folder, either opening them one by one in AUtoCAD, or reading the drawing files as side database.
Here is some code doing that (not tested).
First, find a list of image file names in a drawing:
using System.Collections.Generic;
using Autodesk.AutoCAD.DatabaseServices;
namespace IdentifyRasterImageInDwg
    public static class RasterImageFinder
        public static string[] GetRasterImageNamesInDrawing(Database db)
            List<string> names = new List<string>();
            using (Transaction tran =
                db.TransactionManager.StartTransaction())
                //Get ImageDictionary ID
                ObjectId dictId = RasterImageDef.GetImageDictionary(db);
                if (!dictId.IsNull)
                    DBDictionary dict = (DBDictionary)
                        tran.GetObject(dictId, OpenMode.ForRead);
                    foreach (DBDictionaryEntry entry in dict)
                        RasterImageDef imgDef = (RasterImageDef)
                            tran.GetObject(entry.Value, OpenMode.ForRead);
                        names.Add(imgDef.SourceFileName);
                tran.Commit();
            return names.ToArray();
Above code only search ImageDictionary in a Database to get image source file name of each RasterImageDef object.
Here is the command class that uses above code. The second command method does what you want:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(IdentifyRasterImageInDwg.MyCommands))]
    public class MyCommands
        [CommandMethod("GetImgInDwg")]
        public static void RunMyCommand()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            string[] imgNames =
                RasterImageFinder.GetRasterImageNamesInDrawing(dwg.Database);
            if (imgNames.Length > 0)
                foreach (var name in imgNames)
                    string fileName = System.IO.Path.GetFileName(name);
                    string filePath = System.IO.Path.GetDirectoryName(name);
                    ed.WriteMessage("\nImage name: {0}", fileName);
            else
                ed.WriteMessage("\nNo image is inserted in current drawing.");
            Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        [CommandMethod("SearchDwgForImg")]
        public static void SearchRasterImagesInDrawings()
            string imageFileName = "MyImage.png";
            string folderName = "C:\\Temp";
            List<string> dwgs = new List<string>();
            string[] dwgFiles =
                System.IO.Directory.GetFiles(folderName, "*.dwg");
            foreach (var dwgFile in dwgFiles)
                ed.WriteMessage("\nSearch drawing {0}...",
                    System.IO.Path.GetFileName(dwgFile));
                using (Database db = new Database(false, true))
                    db.ReadDwgFile(
                        dwgFile, System.IO.FileShare.Read, false, null);
                    string[] imgNames =
                        RasterImageFinder.GetRasterImageNamesInDrawing(db);
                        string img = System.IO.Path.GetFileName(name);
                        if (img.ToUpper() == imageFileName.ToUpper())
                            dwgs.Add(dwgFile);
                            break;
            ed.WriteMessage("\n{0} drawing file{1} searched.",
                dwgFiles.Length, dwgFiles.Length > 0 ? "s" : "");
            if (dwgs.Count > 0)
                ed.WriteMessage("\n{0} ha{1} reference to image file {2}:",
                    dwgs.Count, dwgs.Count>1?"ve":"s",imageFileName);
                foreach (var d in dwgs)
                    ed.WriteMessage("\n{0}", d);
            else
                ed.WriteMessage("\nNo drawing file has reference to {0}.", imageFileName);
Well, if you need to search quite some drawings, you may want to use some kind of visual progress indicator to let user know AutoCAD is busy working.
 HTH
Norman Yuan
Drive CAD With Code
”Boost
