.NET
LoaderLock was detected, C# Express 2005
4 REPLIES 4
517 Views, 4 Replies
I changed the 'projectname.csproj.user' file as follows
Program
C:\Program Files\Autodesk Architectural Desktop
2006\acad.exe
This works great but I get the following error when debugging.
error...
"LoaderLock was detected"
message...
"Attempting managed execution inside OS Loader lock. Do not attempt to run
managed code inside a DllMain or image initialization function since doing
so can cause the application to hang."
I can can click the error dialog's continue button to continue with no
problem but I rather know why it happens.
How can I avoid this dialog?
Tks - Paul
4 REPLIES 4
It actually keeps throwing the exception when
you start debugging. Any work around?
Tks - Paul
"Paul Richardson" wrote in message
news:5109107@discussion.autodesk.com...
Program
2006\acad.exe
error...
message...
Tks - Paul
cgay
Paul,
See here....
http://msdn2.microsoft.com/en-us/library/d21c150d(VS.80).aspx
Also, this was discussed here....
http://discussion.autodesk.com/thread.jspa?messageID=5041866
C
Thanks. There was a link to this page on the
error dialog. Plowing through it now. Will
report back if/when I figure it out.
gl - Paul
wrote in message news:5109136@discussion.autodesk.com...
Paul,
See here....
C
look at Jimmie Fulton's post below ".Net 2.0 errors with ADT2006"
Here is his answer...
OK, here is what is required to run VS2005 with AutoCAD 2006. In VS2005, go
to the Debug->Exceptions menu. Within the Exceptions dialog expand the
"Managed Debugging Assistants" node. Look for LoaderLock and uncheck the
"Thrown" column.
Do not disable all MDAs by setting MDA="0" in the registry as it causes
problems.
Hope this helps.
gl - Paul
news:5109155@discussion.autodesk.com...
gl - Paul
Paul,
See here....
C
”Boost
