Load partial cui file
Hello!
I try to load my menu at application start. But I can't see this menu in the menu bar after start. I see menu only after I "reload" current workspace in user interface customization dialog. Does have anybody any idea?
const String myCuiFile = @"D:\Visual Studio 2005\Projects\AutoCAD 2008\Cui\sits.cui";
public void Initialize()
String currentWorkSpace = (String)Application.GetSystemVariable("WSCURRENT");
CustomizationSection acadCustomSection = new CustomizationSection((String)Application.GetSystemVariable("MENUNAME") + ".cui");
if (acadCustomSection.PartialCuiFiles.Contains(myCuiFile) == false)
acadCustomSection.PartialCuiFiles.Add(myCuiFile);
CustomizationSection myCustomSection = new CustomizationSection(myCuiFile);
foreach (Workspace workspace in acadCustomSection.Workspaces)
foreach (PopMenu menu in myCustomSection.MenuGroup.PopMenus)
WorkspacePopMenu workspaceMenu = new WorkspacePopMenu(workspace, menu);
workspaceMenu.Display = 1;
acadCustomSection.Save();
Application.SetSystemVariable("WSCURRENT", currentWorkSpace);
You are changing the CUI file, not the loaded image of it.
You have to do something that causes AutoCAD to reload
the main customization (CUI) file.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5852899@discussion.autodesk.com...
Hello!
I know that I have to do SOMETHING to reload .cui file. 🙂 And
I can unload main .cui file, but I can't load it again. I use "cuiload" command, and this command load acadm.cui file from AutoCAD folder, but I need acadm.cui from Documents And Settings folder. Please, help!
glokhov,
did you find a solution to this, I am having the same problem with the menus not showing after the CUI is loaded at startup.
odurier
Ok same problem
I modify at runtime PartialCui in PrincipalCui.
The change appear in next session of AutoCAD.
How say to AutoCAD reload the main cui at runtime.
Help Tony Help !!!!
jamierobertson1
