• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Load dll-files in Acad2013
    1500 Views, 7 Replies
    03-29-2012 12:42 AM
    Someone already tried to load VB dll's in Acad2013?
    They dont work for me - no message and no error, nothing happens.
    in 2012 they worked well.
    Please use plain text.
    Re: Load dll-files in Acad2013
    03-29-2012 12:44 AM in reply to: s.hofer
    do you mean VB6 dll's oder VB.NET dll's
    Have you set new references (according to AutoCAD 2013/19.0) before you compiled the DLL's?
    A little bit little, your info :smileywink:
    - alfred -
    Alfred NESWADBA
    Active Contributor
    03-29-2012 01:33 AM in reply to: alfred.neswadba
    ahhhh
    you'r right i have to rebuild my scripts with the r19 references...
    i hope this works - i get errors in my code with the new references.
    thanks
    03-29-2012 01:37 AM in reply to: s.hofer
    Yes, there are some modifications necessary to your code as there are some moves of functions/properties to different DLLs/different namespaces. But as long as we don't see what error you have we can't do anything for you :smileywink:
    - alfred -
    Alfred NESWADBA
    Active Contributor
    03-29-2012 02:34 AM in reply to: alfred.neswadba
    ok, one error left...
        Public ReadOnly Property ThisDrawing As AcadDocument
            Get
                Return   Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
            End Get
        End Property
     msg:
    AcadDocument is not a member of Autodesk.AutoCAD.ApplicationServices.Document
    03-29-2012 07:13 PM in reply to: s.hofer
    one global change you have to do is to add a new DLL to the references:
    AcCoreMgd.dll
    To your statement getting asscess to the COM-based AcadDocument you have to use this way:
    Dim tAcadDoc as ApplicationServices.Document
    Dim tAcadDocCOM as Interop.AcadDocument
    tAcadDoc = ApplicationServices.Application.DocumentManager.MdiActiveDocument
    tAcadDocCOM = CType(ApplicationServices.DocumentExtension.GetAcadDocument(tAcadDoc), Interop.AcadDocument)
    HTH, - alfred -
    Alfred NESWADBA
    Active Contributor
    03-29-2012 11:23 PM in reply to: alfred.neswadba
    Ty for your help, but i have a other problem now LOL :smileysad:
    EDIT:
    OK, i updated my project to NETframework 4.0... seems to work now. Thank you very much!
    Active Contributor
    03-30-2012 12:04 AM in reply to: s.hofer
    To get "ThisDrawing" i use
    Return DocumentExtension.GetAcadDocument(Application.DocumentManager.MdiActiveDocument)
     now.
    if someone have the same problem...
