.NET
Active Contributor
s.hofer
Message 1 of 8 (2,563 Views)
Load dll-files in Acad2013
2563 Views, 7 Replies
03-29-2012 12:42 AM
Someone already tried to load VB dll's in Acad2013?
They dont work for me - no message and no error, nothing happens.
in 2012 they worked well.
Alfred.NESWADBA
Message 2 of 8 (2,561 Views)
Re: Load dll-files in Acad2013
03-29-2012 12:44 AM in reply to: s.hofer
do you mean VB6 dll's oder VB.NET dll's
Have you set new references (according to AutoCAD 2013/19.0) before you compiled the DLL's?
A little bit little, your info :smileywink:
- alfred -
Alfred NESWADBA
Active Contributor
s.hofer
Message 3 of 8 (2,553 Views)
03-29-2012 01:33 AM in reply to: Alfred.NESWADBA
ahhhh
you'r right i have to rebuild my scripts with the r19 references...
i hope this works - i get errors in my code with the new references.
thanks
Alfred.NESWADBA
Message 4 of 8 (2,551 Views)
03-29-2012 01:37 AM in reply to: s.hofer
Yes, there are some modifications necessary to your code as there are some moves of functions/properties to different DLLs/different namespaces. But as long as we don't see what error you have we can't do anything for you :smileywink:
- alfred -
Alfred NESWADBA
Active Contributor
s.hofer
Message 5 of 8 (2,546 Views)
03-29-2012 02:34 AM in reply to: Alfred.NESWADBA
ok, one error left...
    Public ReadOnly Property ThisDrawing As AcadDocument
        Get
            Return   Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
        End Get
    End Property
 msg:
AcadDocument is not a member of Autodesk.AutoCAD.ApplicationServices.Document
Alfred.NESWADBA
Message 6 of 8 (2,507 Views)
03-29-2012 07:13 PM in reply to: s.hofer
one global change you have to do is to add a new DLL to the references:
AcCoreMgd.dll
To your statement getting asscess to the COM-based AcadDocument you have to use this way:
Dim tAcadDoc as ApplicationServices.Document
Dim tAcadDocCOM as Interop.AcadDocument
tAcadDoc = ApplicationServices.Application.DocumentManager.MdiActiveDocument
tAcadDocCOM = CType(ApplicationServices.DocumentExtension.GetAcadDocument(tAcadDoc), Interop.AcadDocument)
HTH, - alfred -
Alfred NESWADBA
Active Contributor
s.hofer
Message 7 of 8 (2,502 Views)
03-29-2012 11:23 PM in reply to: Alfred.NESWADBA
Ty for your help, but i have a other problem now LOL :smileysad:
EDIT:
OK, i updated my project to NETframework 4.0... seems to work now. Thank you very much!
Active Contributor
s.hofer
Message 8 of 8 (2,492 Views)
03-30-2012 12:04 AM in reply to: s.hofer
To get "ThisDrawing" i use
Return DocumentExtension.GetAcadDocument(Application.DocumentManager.MdiActiveDocument)
 now.
if someone have the same problem...
You are not logged in.
Ask the Community
