.NET
Load autocad with .net
2 REPLIES 2
241 Views, 2 Replies
I attempting to load AutoCAD(version independent) with vb using AcDbMgd.dll and AcMgd.dll.. As their are many post using .com I can't seem to find one using .net. Please help I have a complete application working with access outside AutoCAD to create layers.
2 REPLIES 2
You are trying to do thing in a wrong way: you cannot use AcadMgd.dll and
acmng.dll to load(start?) AutoCAD, you load AutoCAD first, and load you .NET
ObjectARX dll, which in turn load acadmgd.dll and acmgd.dll. That is, .NET
ObjectARX app can only run inside AutoCAD, so you need start Acad first. Not
the other way around.
If you are talking automating Acad, then yes, you use COM interop if you use
.NET language, or VB5/6. in this case, you do not use acadmgd.dll and
acmgd.dll.
wrote in message news:5322563@discussion.autodesk.com...
Littlerubarb
Thanks.
”Boost
