.NET
Load and run Vlisp program in C#.NET
8 REPLIES 8
Message 1 of 9
connieleo
577 Views, 8 Replies
Could I load and run Vlisp program in C#.NET? Thanks a lot.
8 REPLIES 8
Message 2 of 9
jankoezb
in reply to: connieleo
I suppose you could, but all I can think of is passing AutoCAD the command to load & run a Vlisp program by means of SendStringToExecute(..) method. However, I guess you can't turn off the unpleasant echo that the method generates. Do you know a way to do sort of a verbose command sending, it could be useful. If you do please tell me how 🙂
Janko Jerinic
Message 3 of 9
connieleo
Thanks for your answer. I will try it. : )
Could you explain it in detail? How to SendStringToExecute in the command line and run it? Message was edited by: connieleo
Message 4 of 9
Janko, you may try setting system variables
CMDECHO to 0 and NOMUTT to 1 before issuing a
SendStringToExecute().
Maksim Sestic
Janko Jerinic
Message 5 of 9
jankoezb
Thank you so much Maksim! I figured there must be a way to do that, but I couldn't find out how, mostly because the verb "mutter" wasn't my first choice when querying help files 🙂
Thanks again,
Janko Jerinic
Message 6 of 9
jankoezb
Well, look it up in the .NET API docs. Full name of the method is:
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.SendStringToExecute(..)
You pass it a string containing the command and params and some booleans, look it up. For example.
SendStringToExecute("select\nr\nall", false, false, false)
will deselect all selected objects in the active document, you separate the command and the params with line break symbols.
Janko Jerinic
Message 7 of 9
connieleo
Could anyone tell me how to run lisp in c#.net.I search it. I found someone can do it.
http://discussion.autodesk.com/thread.jspa?messageID=4947476
Could anyone teach me? I attach the lisp file sample. Thanks a lot.
Message 8 of 9
dmarcotte4
Here is an example of how to run your lisp from C#.
Have lot's of fun
Daniel
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace MyFirstCommand
public class MyFirstCommandClass
[CommandMethod("RunLENOF")]
public void CommandRunLENOF()
AcadApp.DocumentManager.MdiActiveDocument.SendStringToExecute("LENOF" + "\x0020", true, false, true);
Message 9 of 9
connieleo
Thanks a lot. It's run.
”Boost
