.NET
Load .NET Project DLL file in AutoCAD LT
2 REPLIES 2
4413 Views, 2 Replies
Can anyone tell me how to load .NET project dll file in AutoCAD LT for customization ?
Becuase in plain AutoCAD command is there named NETLOAD to load DLL file but this command is not working in AutoCAD LT.
2 REPLIES 2
norman.yuan
I am afraid that you cannot do that with Acad LT. You must use full AutoCAD.
Norman Yuan
Drive CAD With Code
In case you want to reduce the dwg size, use "wblock" command, choose "entire drawing" option and save as a new file name. You will have everything in the original drawing just the file size will reduce a lot.
I use LT as well.
”Boost
