Solved by owenwengerd. Go to Solution.
No, the auto loader will not work with 2008-2009 series.
It will work from 2012 series.
Hi
I have found this code which is similar to my requirement but it requires TLOD command to run and what my requirement is to load the lisp without running the command TLOD.
http://forums.autodesk.com/t5/NET/load-and-run-lsp-from-C/td-p/2547034
Please guide me someone.
Far, far easier to load and manage LISP through LISP, and call LISP functions defined in dotNET. Try to call "down" from dotNET to LISP is usually better avoided in favor of rebuilding the LISP content as dotNET.
A single line or two is one of the few areas where LISP shines over dotNET. If all you want is a couple of function calls like (vl-load-com) they can be stuffed into the acaddoc.lsp file without needing to build, demand-load, modify the registry, or anything.
Perhaps this will be of interest:
Building a commercial grade lisp plugin installer in 5 easy steps
