Load AutoCAD from VB.Net (Newbie)
Can someone help me to:
1. Connect to AutoCAD 2004 or higher using VB.Net
2. Open AutoCAD if not open already
3. Open a drawing if AutoCAD is already open.
All help will be greatly appreciated.
Cujo
PS - presume I am starting with only a drawing name so if there are imports, etc. I'll need those as well.
Thanks!!!!!
I'm very new to VB.net too, but play with it
occasionally.  Here is a way to open a cad dwg, then renaming it.  The
form has two buttons on it, one labeled to start and one to save
as.
Inherits
System.Windows.Forms.Form
Region " Windows Form
Designer generated code "
Public
color=#0000ff size=2>Sub
size=2>New
MyBase.New()
'This call is required by the Windows Form
Designer.
InitializeComponent()
'Add any initialization after the
InitializeComponent() call
End
'Form overrides dispose to clean up the
component list.
Protected
color=#0000ff size=2>Overloads
size=2>Overrides
size=2>Sub
Dispose(
size=2>ByVal
disposing
size=2>As
size=2>Boolean
If disposing
Then
If
color=#0000ff size=2>Not
(components
color=#0000ff size=2>Is
size=2>Nothing
size=2>Then
components.Dispose()
End
color=#0000ff size=2>If
End
MyBase
size=2>.Dispose(disposing)
End
'Required by the Windows Form
Designer
Private components
As
System.ComponentModel.IContainer
'NOTE: The following procedure is required
by the Windows Form Designer
'It can be modified using the Windows Form
Designer.
'Do not modify it using the code
editor.
Friend
color=#0000ff size=2>WithEvents
Button1
color=#0000ff size=2>As
System.Windows.Forms.Button
Friend
Button2
<System.Diagnostics.DebuggerStepThrough()>
size=2>Private
size=2>Sub
Me.Button1 =
New
Me.Button2 =
New
Me.SuspendLayout()
'Button1
Me.Button1.Location =
New
System.Drawing.Point(56, 232)
Me.Button1.Name =
"Button1"
Me.Button1.TabIndex =
0
Me.Button1.Text =
"Start Cad"
'Button2
Me.Button2.Location =
New
System.Drawing.Point(152, 232)
Me.Button2.Name =
"Button2"
Me.Button2.TabIndex =
1
Me.Button2.Text =
"SaveAs"
'Form1
Me.AutoScaleBaseSize =
New System.Drawing.Size(5,
13)
Me.ClientSize =
New
System.Drawing.Size(292, 273)
Me
size=2>.Controls.Add(
Me
size=2>.Button2)
Me
Me
size=2>.Button1)
Me.Name = "Form1"
Me.Text = "Form1"
Me
size=2>.ResumeLayout(
False
size=2>)
End
End
color=#0000ff size=2>Region
' Private output As
FileStream
' Dim myStream As Stream
size=2>
' Dim openFileDialog1 As New
OpenFileDialog
Dim myCad
Autodesk.AutoCAD.Interop.AcadApplication
Dim myDwg
Autodesk.AutoCAD.Interop.AcadDocument
Private
Button1_Click(
color=#0000ff size=2>ByVal
sender
size=2>As
System.Object,
size=2>ByVal
e
size=2>As
System.EventArgs)
size=2>Handles
Button1.Click
Dim openFileDialog1
As
color=#0000ff size=2>New
OpenFileDialog
openFileDialog1.Filter = ("Drawing|*.dwg")
myCad =
New
myDwg =
New
End
Private
Button2_Click(
sender
size=2>As
System.Object,
size=2>ByVal
e
size=2>As
System.EventArgs)
size=2>Handles
Button2.Click
Dim myStream
As Stream
Dim saveFileDialog1
As
SaveFileDialog
Dim strCurName
As
color=#0000ff size=2>String
saveFileDialog1.Filter = "Drawing Files (*.dwg)|*.dwg"
saveFileDialog1.FilterIndex = 1
saveFileDialog1.RestoreDirectory =
size=2>True
saveFileDialog1.ShowDialog()
strCurName = saveFileDialog1.FileName.ToString
myCad.ActiveDocument.SaveAs(strCurName)
End
End
size=2>Class
Can
someone help me to:
VB.Net
3.  Open a drawing
appreciated.
Cujo
well.
Thanks!!!!!
I noticed I let some of the trash in my code, sorry
about that, you can get rid of some of the comments and anything to do with
stream.   It was just some stuff I was playing with.  Also, you
must add in the autocad reference.  Depending on what you want to do with
your dwgs, add the respective references.  Below is the same thing cleaned
up.
Mike
color=#0000ff size=2>Dim
myCad
size=2>As
Dim myDwg
As
Private
Button1_Click(
sender
System.Object,
e
size=2>As
System.EventArgs)
size=2>Handles
Button1.Click
Dim openFileDialog1
As
OpenFileDialog
myCad = New
myDwg = New
End
Private
Button2_Click(
sender
System.Object,
e
size=2>As
System.EventArgs)
size=2>Handles
Button2.Click
Dim saveFileDialog1
As
SaveFileDialog
Dim strCurName
As
size=2>True
End
End
size=2>Class
style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none">
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
style="mso-spacerun: yes">
style="COLOR: blue">Dim
myCad As
myDwg As
style="COLOR: blue">Private
Sub
Button1_Click(ByVal sender
style="COLOR: blue">As
System.Object,
style="COLOR: blue">ByVal
e As
System.EventArgs) Handles
Button1.Click
Dim blnRunning
style="COLOR: green">' As Boolean
Dim objProcess
style="COLOR: green">' As Object
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">
' check to see if Acad is already running if
running, do not start new instance of program
blnRunning = False
style="FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: 'Courier New'">
For
style="COLOR: blue">Each
objProcess In
GetObject("winmgmts:").ExecQuery("select * from
Win32_Process")
If LCase(objProcess.Name) = "acad.exe"
Then
blnRunning = True
Exit
style="COLOR: blue">For
End
style="COLOR: blue">If
Next '
objProcess
' if acad is not running start up the
application
If Not
(blnRunning) Then
Dim openFileDialog1
New
OpenFileDialog
Dim dwg
myCad = New
End
' open a new dwg in acad
application
myDwg = New
style="COLOR: blue">End
style="COLOR: blue">Sub
face=Arial color=#000000>This will be the last sample I'll bother you with, as I
mentioned, I'm new to VB programming too and thought I should try out the
things I posted.  It wasn't too stable so this gives more
stability if you open more than one dwg at a time.
HTH
face=Arial color=#000000>Mike
Sub
Button2_Click(ByVal sender
System.Object,
e As
Button2.Click
Dim myStream
Stream
Dim saveFileDialog1
New
SaveFileDialog
Dim strCurName
style="COLOR: blue">String
' save active open dwg to new
name
(*.dwg)|*.dwg"
style="COLOR: blue">True
myDwg = myCad.ActiveDocument
myDwg.SaveAs(strCurName)
Can
someone help me to:
VB.Net
3.  Open a drawing
appreciated.
Cujo
well.
Thanks!!!!!
