.NET
Active Contributor
Fredrik.Larsen
Message 1 of 5 (319 Views)
Listen for escape pressed
319 Views, 4 Replies
01-04-2013 02:57 AM
Hi
Is there a way to add a listener so I am told when escape(cancel command) is pressed? I want to create a cancel pressed event.
Moderator
Alexander.Rivilis
Message 2 of 5 (296 Views)
Re: Listen for escape pressed
01-04-2013 08:24 AM in reply to: Fredrik.Larsen
This way can help you:
How to implement a Windows Hook using acedRegisterFilterWinMsg in .NET
In WindowHookProc event handler you can check msg.Msg == WM_KEYDOWN (0x0100)  and msg.WParam == VK_ESCAPE (0x1B)
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
Fredrik.Larsen
Message 3 of 5 (249 Views)
01-07-2013 12:58 AM in reply to: Alexander.Rivilis
Thanks, that seems to work, but how do you unregister the listener? When escape is pressed I want to do something and then unregister the listener.
Moderator
Alexander.Rivilis
Message 4 of 5 (238 Views)
01-07-2013 02:36 AM in reply to: Fredrik.Larsen
In order to unregister this event handler use function acedRemoveFilterWinMsg:
BOOL acedRemoveFilterWinMsg(
    const AcedFilterWinMsgFn pfn
In C# it is look like:
// For AutoCAD 2013 64 bit
// On previous versions, import from acad.exe (instead accore.dll)
[DllImport("accore.dll",  CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedRemoveFilterWinMsg@@YAHQ6AHPEAUtagMSG@@@Z@Z")]
private static extern int acedRemoveFilterWinMsg( WindowHookProc callBackFunc );
Active Contributor
Fredrik.Larsen
Message 5 of 5 (232 Views)
01-07-2013 03:11 AM in reply to: Alexander.Rivilis
Thank you very much.
You are not logged in.
Ask the Community
