Lisp "_ERASE" to .net com VB
Hi all,
i want delete some Models in MODELL Drawing without the LISP "_ERASE" because its stop when doesent have a named group in the drawing.
any Idears or Hints for deleting in .Net with a com addin?
thx for help
Mario
Balaji_Ram
If I understand your question correctly, you would like to remove block table records from the drawing through your external exe using the COM API . Correct me if this is not what you wanted.
Here is a code snippet to get you started :
Dim acApplication As AcadApplication = Nothing
Dim progID As String = "AutoCAD.Application.18.1"
' Get the running instance of AutoCAD or start a new one.
Try
	acApplication = DirectCast(Marshal.GetActiveObject(progID), AcadApplication)
	acApplication.Visible = True
Catch comexception As COMException
	acApplication = New AcadApplication()
End Try
Dim activeDocument As AcadDocument = acApplication.ActiveDocument
Dim db As AcadDatabase = activeDocument.Database
' Iterate through the blocks and erase a block named "Test" if it exists.
Dim acadBlocks As AcadBlocks = activeDocument.Blocks
For cnt As Integer = 0 To acadBlocks.Count - 1
	Dim acadBlock As AcadBlock = acadBlocks.Item(cnt)
	If acadBlock.Name.Equals("Test") Then
		acadBlock.[Erase]()
Next
Balaji
Developer Technical Services
Autodesk Developer Network
