Line intersect with block
Hi All,
I find the intersected point of Line and block as this code:
'bref is a block reference
Dim tmpLine As New Line(pt1, bref.Position)
Dim ptCol As New Point3dCollection
bref.IntersectWith(tmpLine, Intersect.OnBothOperands, ptCol, 0, 0)
Dim acLine As New Line(pt1,ptCol(0))
 But the intersected point is not located on block as picture below. I don't know what happen.
Thank you for any help.
Alexander.Rivilis
It is look like you found intersect point which on bounding box of block reference:
Intersecting any entity with a BlockReference and retrieving the intersection points
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
I found the intersecting point of line and bounding box of block reference. Can you help me with VB.net code.
Alexander.Rivilis
Easiest way is explode BlockRerence (method BlockReference.Explode but without adding entities to Database) and then intersect your's line with every entity in collection of exploded entities (maybe recursive if entity in collection is also BlockReference).
Expert Elite Member
