.NET
Launching AutoCAD from a .NET application
2 REPLIES 2
alex_b
803 Views, 2 Replies
I'm trying to launch AutoCAD 2012 from an out-of-process .NET application, based on Kean Walmsley's code at http://through-the-interface.typepad.com/through_the_interface/2007/12/launching-autoc.html#comment-...
While this works OK for V2004 and V2008, it crashes A2012. The crash is erraticall, but usually occurs when launching a UI-based command (Layer manager, Open dialog, etc.)
It seems somehow to be related to UI-thread blocking. (the app launches AutoCAD, may communicate with it, and stays there waiting for it to exit).
Anybody experienced this?
alex
2 REPLIES 2
ProfWolfMan
in reply to: alex_b
Hi Alex,
I do not know exact solution of your problem.
Meanwhile, you can have a look on the following code, which is used by myself since AutoCAD2008 wihtout any issues.
 Dim AcadApp As Object
        Try
            AcadApp = GetACAD()
            If IsNothing(AcadApp) Then
                MsgBox("Cannot get AutoCAD application.Open AutoCAD and try again.", MsgBoxStyle.Information)
                End
Public Function GetACAD() As Object
        Dim regs As Microsoft.Win32.RegistryKey = Nothing
        Dim AcadObj As Object = Nothing
        Try
            regs = Microsoft.Win32.Registry.CurrentUser.OpenSubKey("SOFTWARE\Autodesk\AutoCAD\R19.1")
            If regs IsNot Nothing Then AcadObj = GetAcadOpp("19")
            If IsNothing(AcadObj) = False Then Return AcadObj
            regs = Microsoft.Win32.Registry.CurrentUser.OpenSubKey("SOFTWARE\Autodesk\AutoCAD\R18.2")
            If regs IsNot Nothing Then AcadObj = GetAcadOpp("18")
            regs = Microsoft.Win32.Registry.CurrentUser.OpenSubKey("SOFTWARE\Autodesk\AutoCAD\R18.1")
            regs = Microsoft.Win32.Registry.CurrentUser.OpenSubKey("SOFTWARE\Autodesk\AutoCAD\R18.0")
            regs = Microsoft.Win32.Registry.CurrentUser.OpenSubKey("SOFTWARE\Autodesk\AutoCAD\R17.2")
            If regs IsNot Nothing Then AcadObj = GetAcadOpp("17")
            regs = Microsoft.Win32.Registry.CurrentUser.OpenSubKey("SOFTWARE\Autodesk\AutoCAD\R17.1")
        Catch ex As Exception
            MsgBox("Error Getting AutoCAD Info " & ex.Message)
            Return Nothing
        End Try
        Return Nothing
    End Function
    Private Function GetAcadOpp(ByVal AcadString As String) As Object
        Dim AcadApp As Object = Nothing
        Try
            Select Case (AcadString)
                Case "19"
                    AcadApp = GetObject(, "AutoCAD.Application.19")
                Case "18"
                    AcadApp = GetObject(, "AutoCAD.Application.18")
                Case "17"
                    AcadApp = GetObject(, "AutoCAD.Application.17")
            End Select
            If Not AcadApp Is Nothing Then Return AcadApp
            AcadApp = Nothing
        Finally
        End Try
            Try
                    Case "19"
                        AcadApp = CreateObject("AutoCAD.Application.19")
                    Case "18"
                        AcadApp = CreateObject("AutoCAD.Application.18")
                    Case "17"
                        AcadApp = CreateObject("AutoCAD.Application.17")
                End Select
                AcadApp = Nothing
            Finally
            End Try
        Return AcadApp
    End Function
Thanks & Regards,
G
Tags (1)
alex_b
in reply to: ProfWolfMan
Hi ProfWolfMan,
My code (in C#) is essentially the same as yours.
To explain a bit more: the code launches Autocad and can communicate with and drive it; the problem is if the user tries to use it in the normal manner, then it crashes. It happens only in V2012.
Do you use console application or GUI?
alex
”Boost
