.NET
Large Preview of .dwg File for VB.Net Application
23 REPLIES 23
Message 1 of 24
vampirefromtheITcave
3165 Views, 23 Replies
I need to display a large preview of a .dwg file in my VB.Net application. A thumbnail will not work, I need a much larger image so that users can view the preview in more detail. Resizing the thumbnail will result in the loss of far too much detail. Is there a component or other way to display a large preview of a .dwg file.
23 REPLIES 23
Message 21 of 24
in reply to: vampirefromtheITcave
Look's like you're out of options.
Rendering views of a DWG file requires megabytes of code,
whether it be from Autodesk, ODA, or someone else.
wrote in message
news:6222257@daiscussion.autodesk.com...
That solution is way too expensive for my company. I need something much
cheaper.
Message 22 of 24
Up and running with AutoDWG DWGViewX in x86 mode. Edited by: vampirefromtheITcave2 on Jul 23, 2009 1:50 PM
Message 23 of 24
Thats a little odd - we're on our third generation (upgrading to 2010 version shortly) of TrueView and haven't had any install problems across a variety of computers and Win-based operating systems. Still, glad you found a path forward.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 24 of 24
Not .NET
Have you seen CadLib (that read and creates DXF files) it is an old class
located at cadproject.com
http://www.codeproject.com/KB/library/cadlib.aspx
In C#
There is one named DXFreader at codeproject.com
http://www.codeproject.com/KB/cs/dxfreader.aspx
Might be of some help or a start.
”Boost
