.NET
LOADING MODAL DIALOG
1 REPLY 1
sybold
372 Views, 1 Reply
I'm trying to load a modal dialog, at the first loaded/created drawing.
how can i find out when autocad is done with loading to activate the form
I have event handlers for document created but it gets called to early.
any ideas?
1 REPLY 1
StephenPreston
in reply to: sybold
Its not completely clear to me what you need exactly from your description, and not sure if this will give you what you need, but you could look at the IsQuiescent property and the EnteringQuiescentState event.
Cheers,
Stephen Preston
Autodesk Developer Network
”Boost
