.NET
SENL1362
Message 11 of 13 (118 Views)
Re: Key Point
12-27-2013 12:46 PM in reply to: HelloWorlddd
solved it ?
SENL1362
Message 12 of 13 (111 Views)
Re: Key Point
12-27-2013 03:40 PM in reply to: SENL1362
This may get  you on track
using System;
using System.Collections.Generic;
using System.Text;
using System.Text.RegularExpressions;
using System.IO;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
namespace line2Circle
    public class Class1
        [CommandMethod("l2c")]
        public void LineTwoCircle()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                BlockTableRecord ms = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                PromptEntityOptions promptForLine = new PromptEntityOptions("\nSelect the Line:");
                promptForLine.SetRejectMessage("Lines only");
                promptForLine.AddAllowedClass(typeof(Line), true);
                PromptEntityResult getLineRes = ed.GetEntity(promptForLine);
                if (getLineRes.Status != PromptStatus.OK)
                    return;
                Line ln = (Line)tr.GetObject(getLineRes.ObjectId, OpenMode.ForRead);
                ed.WriteMessage("\nLine: {0}..{1}", ln.StartPoint, ln.EndPoint);
                PromptEntityOptions promptForCircle = new PromptEntityOptions("\nSelect a Circle:");
                promptForLine.SetRejectMessage("Circles only");
                promptForLine.AddAllowedClass(typeof(Circle), true);
                PromptEntityResult getCircleRes = ed.GetEntity(promptForCircle);
                if (getCircleRes.Status != PromptStatus.OK)
                    return;
                Circle cir = (Circle)tr.GetObject(getCircleRes.ObjectId, OpenMode.ForRead);
                ed.WriteMessage("\nCircle: {0},{1}", cir.Center,cir.Radius);
                Circle tmpCircle = new Circle(cir.Center, new Vector3d(0,0,1),cir.Radius + 1);
                tmpCircle.SetDatabaseDefaults(db);
                ms.AppendEntity(tmpCircle);
                tr.AddNewlyCreatedDBObject(tmpCircle, true);
                Point3dCollection interSections = new Point3dCollection();
                ln.IntersectWith(tmpCircle, Intersect.ExtendThis, interSections, 0, 0);
                if (interSections.Count < 0)
                    ed.WriteMessage("\nFault: Line does not intersect with this circle");
                else
                    for (int i = 0; i < interSections.Count; i++)
                        ed.WriteMessage("\nIntersection[{0}={1}", i, interSections[i]);
                    if (ln.StartPoint.DistanceTo(interSections[0]) < ln.EndPoint.DistanceTo(interSections[0]))
                        ln.ReverseCurve();
                    Point3d peNew = interSections[0];
                    if (ln.StartPoint.DistanceTo(peNew) > ln.StartPoint.DistanceTo(interSections[1]))
                        peNew = interSections[1];
                    //Next lines modify the source line.
                    //ln.UpgradeOpen();
                    //ln.EndPoint = peNew;
                    //for debug mode w'll create a new (Temporary) line
                    Line tmpLn = new Line(ln.StartPoint, peNew);
                    tmpLn.SetDatabaseDefaults(db);
                    ms.AppendEntity(tmpLn);
                    tr.AddNewlyCreatedDBObject(tmpLn, true);
                //double dX = ln.EndPoint.X - ln.StartPoint.X;
                //double dY = ln.EndPoint.Y - ln.StartPoint.Y;
                //Point3d ps = cir.Center;
                //double xPe=cir.Center.X-dY;
                //double yPe=cir.Center.Y+dX;
                //Point3d pe = new Point3d(xPe, yPe, cir.Center.Z);
                //Line lnPp = new Line(ps, pe);
                //lnPp.SetDatabaseDefaults(db);
                //ms.AppendEntity(lnPp);
                //tr.AddNewlyCreatedDBObject(lnPp, true);
                //Point3dCollection interSections = new Point3dCollection();
                //ln.IntersectWith(lnPp, Intersect.ExtendBoth, interSections, 0,0);
                //ed.WriteMessage("\n Intersection={0}", interSections[0]);
                //lnPp.EndPoint = interSections[0];
                //if (lnPp.Length > cir.Radius)
                //    ed.WriteMessage("\nNo intersection with the Circle");
                //else if  (lnPp.Length < cir.Radius)
                //    ed.WriteMessage("\nTwo intersection with the Circle");
                //else
                //    ed.WriteMessage("\nOne exact intersection with the Circle");
                tr.Commit();
Valued Contributor
HelloWorlddd
Message 13 of 13 (95 Views)
Re: Key Point
12-28-2013 09:22 AM in reply to: SENL1362
   Yes, I solved it by this Message from this Form as you said:
   Measure perpendicular distance between 2 polylines
   Very thanks
You are not logged in.
Announcements
Need installation help?
Ask the Community
