Keep Block Selected after insert - BlockExplodeHelper.cs
SRSDS
Advisor Advisor
SRSDS
Hi, does anyone have Tony's BlockExplodeHelper class?
In particular I need to keep a block selected after it is inserted. For some reason the ObjectModified event is triggered after my insertion code that deselects it. The BlockExplodeHelper might have a solution.
ed.SetImpliedSelection(psr.Value)
Otherwise can anyone suggest a solution?
Alfred.NESWADBA
sorry I don't have the libraryyou mentioned. But to get a blockreference gripped after it is inserted I see no problem (without having a look to your code). Look my sample (a block 'TEST' has to exist) it grips after having inserted the block.
   Public Shared Function insertBlRefAndGrip() As Boolean
      Dim tRetVal As Boolean = False
      Dim tAcadDoc As Document = Nothing
      Dim tAcadDocLock As DocumentLock = Nothing
      Dim tTrAct As Transaction = Nothing
      Try
         tAcadDoc = Application.DocumentManager.MdiActiveDocument
         tAcadDocLock = tAcadDoc.LockDocument
         tTrAct = tAcadDoc.TransactionManager.StartTransaction
         Dim tBlTab As BlockTable = CType(tTrAct.GetObject(tAcadDoc.Database.BlockTableId, OpenMode.ForRead), BlockTable)
         'check if BlockDef "TEST" exists and is valid
         If tBlTab.Has("TEST") Then
            Dim tBlDefID As ObjectId = tBlTab.Item("TEST")
            If (tBlDefID.IsValid) AndAlso (Not tBlDefID.IsErased) Then
               'get current space to insert the blockref
               Dim tSpace As BlockTableRecord = CType(tTrAct.GetObject(tAcadDoc.Database.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
               'insert blockref
               Dim tBlRef As BlockReference = New BlockReference(Point3d.Origin, tBlDefID)
               Dim tBlRefID As ObjectId = tSpace.AppendEntity(tBlRef)
               tTrAct.AddNewlyCreatedDBObject(tBlRef, True)
               tTrAct.Commit()
               'grip blockref
               Dim tObjIDs() As ObjectId = {tBlRefID}
               tAcadDoc.Editor.SetImpliedSelection(tObjIDs)
               tRetVal = True
            Else
               Call MsgBox("Block 'TEST' is purged")
         Else
            Call MsgBox("Block 'TEST' not defined")
      Catch ex As Exception
         Call MsgBox("Error occured!" & vbNewLine & ex.Message)
      Finally
         If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing
         If tAcadDocLock IsNot Nothing Then tAcadDocLock.Dispose() : tAcadDocLock = Nothing
      End Try
      Return tRetVal
   End Function
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
SRSDS
Thanks Alfred,
I've worked out what the problem was.
The block I am inserting has constrained dimensions and for the dimensions to be kicked into position I need regen.
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("DIMREGEN ", True, False, False)
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("REGEN ", True, False, False)
Adding the SetImpliedSelection() after the regen I can see that it is selected but only for a fraction of a second before being deselected. Don't know why.
I might have to live with it.
Alfred.NESWADBA
>> Adding the SetImpliedSelection() after the regen [...]
Wrong attempt to solve it, because the SendCommand in your could runs asynchronous (I assume that all yoru code was started via a command). So you set the commands "DIMREGEN" and "REGEN" in top of the command-stack, then you did the SetImpliedSelection .... then your command finished ==> and now the stack ships the buffered commands to the command-line.
In other words your REGEN's where done after your code, and so after you SetImpliedSelection.
- alfred -
Alfred NESWADBA
SRSDS
It seems to be the same effect if added before or after the regen.
If I remove the regen it retains the selection.
Code is started from a pallette button.
Alfred.NESWADBA
Yes, you are right and I try do describe it better.
Within your code you wrote:
SendCommand DIMREGEN
SendCommand REGEN
AutoCAD starts
a) your command
     a1) add "DIMREGEN" to the command-stack
     a2) add "REGEN" to the command-stack
     a3) SetImpliedSelection
b) your command finished
c) start "DIMREGEN" from command-stack
d) start "REGEN" from command-stack
So whereever you do the SetImpliedSelection within your running command, it will always start before the command "REGEN" will be executed.
Hope it's more clear described now 😉
- alfred -
Alfred NESWADBA
SRSDS
Sorry Alfred,
I can't seem to find out how to organise commands in the command stack . This is the first I've heard of it and can't seem to find any information on the forum. Great to hear there is a solution though and really appreciate the help.
