.NET
JLS3
2 REPLIES 2
289 Views, 2 Replies
JLS3
How to get the ObjectId of an existing block in c#
2 REPLIES 2
Hallex
Do you want to get ObjectId of BlockReferece (graphical instance of Block Definition)
 or of Block Definition itself?
There is a two different objects btw
Hallex
Hetre is quick code hope this will  make a sence
       [CommandMethod("testblock")]
        public static void TestBlocks()
            string blockName = "dyn";
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
             Transaction tr = db.TransactionManager.StartTransaction();
             using (tr)
                 try
                     BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                     if (!bt.Has(blockName))
                         ed.WriteMessage("\nBlock \"{0}\" does not exist", blockName);
                         return;
                     ObjectId blkID = bt[blockName];
                     ed.WriteMessage("\nBlock \"{0}\" does exist, ObjectId is: {1}", blockName, blkID);
                     BlockTableRecord btr = tr.GetObject(bt[blockName], OpenMode.ForRead) as BlockTableRecord;
                     ObjectIdCollection blkRefIds = btr.GetBlockReferenceIds(true, false);
                     if (blkRefIds.Count == 0)
                         ed.WriteMessage("\nNo block instances \"{0}\" found", blockName);
                         return;
                     foreach (ObjectId brefId in blkRefIds)
                         BlockReference blkRef = (BlockReference)tr.GetObject(brefId, OpenMode.ForRead, false) as BlockReference;
                         ed.WriteMessage("\nBlock Reference \"{0}\" with ObjectID {1} found  at position: {2}", blkRef.Name, brefId,blkRef.Position);
                     tr.Commit();//optional in this context
                 catch (Autodesk.AutoCAD.Runtime.Exception ex)
                     ed.WriteMessage(("AutoCAD Exception: " + ex.Message));
                 catch (System.Exception ex)
                     ed.WriteMessage(("Sytem Exception: " + ex.Message));
                 finally
                     // optional
~'J'~
”Boost
