.NET
JIG multiple entities
16 REPLIES 16
Message 1 of 17
ditran7577
4244 Views, 16 Replies
Hi Pro,
How to Jig multiple entities such as insert a block and add a line.
16 REPLIES 16
Message 2 of 17
_gile
in reply to: ditran7577
hi,
You can build a class which derives from DrawJig.
Here's a little example to drag multiple entities. The entites passed to DragEntitiesJig instance have to be opened within a transaction.
    class DragEntitiesJig : DrawJig
        Point3d basePoint, dragPoint;
        IEnumerable<Entity> ents;
        public DragEntitiesJig(IEnumerable<Entity> ents, Point3d basePoint)
            this.basePoint = basePoint;
            this.ents = ents;
        protected override bool WorldDraw(WorldDraw draw)
            WorldGeometry wGeom = draw.Geometry;
            Matrix3d disp = Matrix3d.Displacement(this.basePoint.GetVectorTo(this.dragPoint));
            wGeom.PushModelTransform(disp);
            foreach (Entity ent in this.ents)
                wGeom.Draw(ent);
            wGeom.PopModelTransform();
            return true;
        protected override SamplerStatus Sampler(JigPrompts prompts)
            JigPromptPointOptions options = new JigPromptPointOptions("\nSecond point: ");
            options.BasePoint = this.basePoint;
            options.UseBasePoint = true;
            options.Cursor = CursorType.RubberBand;
            options.UserInputControls = UserInputControls.Accept3dCoordinates;
            PromptPointResult ppr = prompts.AcquirePoint(options);
            if (ppr.Value.IsEqualTo(this.dragPoint))
                return SamplerStatus.NoChange;
            this.dragPoint = ppr.Value;
            return SamplerStatus.OK;
Gilles Chanteau
GileCAD
GitHub
Message 3 of 17
If you google internet you look many samples. For example:
http://forums.autodesk.com/t5/NET/Multiple-entities-jig/td-p/2304511
http://spiderinnet1.typepad.com/blog/2012/05/autocad-net-use-drawjig-to-move-multiple-entities-as-ma...
http://through-the-interface.typepad.com/through_the_interface/2007/05/using_a_jig_fro.html
http://through-the-interface.typepad.com/through_the_interface/2009/03/jigging-an-autocad-block-with...
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 4 of 17
Hallex
Here is code example very limited tested on A2010
see if this works,keep in mind, to change Clone method jn
DeepCloneObjects if your entities have Xdata embedded
        // based on Kean Walmsley example (jig mtext)
         [CommandMethod("dej")]
        public void MoveCopyJig()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = HostApplicationServices.WorkingDatabase;
            Editor ed = doc.Editor;
            try
                using (Transaction tr = doc.TransactionManager.StartTransaction())
                    SelectionSet sset = ed.GetSelection().Value;
                    Point3d basept = ed.GetPoint("\nBase point: ").Value;
                    IEnumerable<Entity> objs = sset.GetObjectIds().Select(x => (Entity)tr.GetObject(x, OpenMode.ForRead)).ToArray();
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    foreach (Entity e in objs)
                        Entity c = (Entity)e.Clone();// you may want to use DeepCloneObjects instead
                        btr.AppendEntity(c);
                        tr.AddNewlyCreatedDBObject(c, true);
                    ed.SetImpliedSelection(sset);
                    PromptSelectionResult psr = ed.SelectImplied();
                    // drag our jig
                    if (psr.Status == PromptStatus.OK)
                        // jig whole selection
                          ed.Drag(
                            psr.Value,
                            "\nSpecify displacement point: ",
                            delegate(Point3d pt, ref Matrix3d mat)
                                // If no change has been made, say so
                                if (basept == pt)
                                else
                                    // Otherwise we return the displacement
                                    // matrix for the current position
                                    mat = Matrix3d.Displacement(basept.GetVectorTo(pt)
                        // Assuming it works, transform our MText
                        // appropriately
                        if (ppr.Status == PromptStatus.OK)
                            // Get the final translation matrix
                            Matrix3d mat = Matrix3d.Displacement(basept.GetVectorTo(ppr.Value)
                            foreach (Entity en in objs)
                                en.UpgradeOpen();
                                en.TransformBy(mat);
                        // Finally we commit our transaction
                        tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage(ex.ToString());
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 5 of 17
JanetDavidson
in reply to: _gile
Hello Gile,
I needed this and as usual, you solved it by simplest way.
Cheers,
Message 6 of 17
a.kouchakzadeh
in reply to: _gile
Giles, Hi
I was wondering how can I jig multiple block references with one base point using JIG?
I understood that in order to use your method and IEnumerable, I have to use yield return which requires object ID. but my block reference is not created yet to have an objectID.
Message 7 of 17
@a.kouchakzadeh wrote:
...I understood that in order to use your method and IEnumerable, I have to use yield return which requires object ID. but my block reference is not created yet to have an objectID.
You have to yield return not ObjectId but Entity.
Expert Elite Member
Message 8 of 17
_gile
in reply to: a.kouchakzadeh
The DragEntitiesJig constructors requires an IEnumerable<Entities> as argument, not an IEnumerable<ObjectId>.
That said, you can pass this constructor any generic collection type which implements the IEnumerable<Entity> interface such as a List<Entity> or Entity[].
Gilles Chanteau
GileCAD
GitHub
Message 9 of 17
a.kouchakzadeh
in reply to: _gile
thanks for the reply to both of you.
Giles, I modified your code because I didnt want the basepoint option. now I have a problem:
I cant see the block ref moving with my cursor. its only at (0,0,0).
what Im I doing wrong?
        Point3d dragPoint;
        public DragEntitiesJig(IEnumerable<Entity> ents)
            this.ents = ents;
                wGeom.Draw(ent);
            return true;
            var options = new JigPromptPointOptions();
            options.UserInputControls = (UserInputControls.Accept3dCoordinates);
            var result = prompts.AcquirePoint(options);
            if (dragPoint.IsEqualTo(result.Value))
            else
                dragPoint = result.Value;
and this is my test method:
public class JigTest
        [CommandMethod("test")]
        public void Test()
            var doc = acap.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            var db = doc.Database;
            using (var tr = db.TransactionManager.StartTransaction())
                var blkTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                var blk1 = new ObjectId();
                var blk2 = new ObjectId();
                var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                blk1 = blkTable["1"];
                blk2 = blkTable["2"];
                var blkref1 = new BlockReference(Point3d.Origin, blk1);
                var blkref2 = new BlockReference(Point3d.Origin, blk2);
                var blkList = new List<Entity>()
                    blkref1,
                    blkref2
                var jig = new DragEntitiesJig(blkList);
                var jigResult = ed.Drag(jig);
                if (jigResult.Status == PromptStatus.OK)
                    curSpace.AppendEntity(blkref1);
                    tr.AddNewlyCreatedDBObject(blkref1, true);
                    curSpace.AppendEntity(blkref2);
                    tr.AddNewlyCreatedDBObject(blkref2, true);
                tr.Commit();
also can you tell me how to modify the class driven from EntityJig to get multiple entities?  can I remove :base(br) in the line :
public JigBlockReference(BlockReference br)
            : base(br)
public class JigBlockReference : EntityJig
        protected Point3d dragPoint;
        protected BlockReference br;
            : base(br)
            this.br = br;
            dragPoint = br.Position;
                "\nSpecify destination point or rotate 90° [Left/Right]: ", "Left Right");
            options.UserInputControls = (UserInputControls.GovernedByOrthoMode);
            else
        protected override bool Update()
            br.Position = dragPoint;
            return true;
Message 10 of 17
_gile
You need a base point to define the displacement from this base to the cursor (dragPoint), and you need to call PushModelTransform passing it this displacement to see the block moving.
            : base(br
EntityJig is to be used to jig a single entity and the derived class must pass this entity to the base class.
Gilles Chanteau
GileCAD
GitHub
Message 11 of 17
a.kouchakzadeh
in reply to: _gile
 can you please give me an example how to do it?
Message 12 of 17
_gile
Here's an example inspired your upper one. The "base point" is Point3d.Origin (insertion point of newly created block references).
To make the Test command safer, it checks if the current drawing block table contains "1" and "2" block definitons, and use s using statements to ensure the disposing of newly created block references in case they're not added to the  transaction (i.e. the user cancels the jig).
        [CommandMethod("TEST")]
        public void Test()
                // check if the block table has "1" and "2" blocks
                if (!(blkTable.Has("1") && blkTable.Has("2")))
                    return;
                // wrap the newly created block reference in using statements to ensure
                // they're disposed in case the user cancels the jig
                using (var blkref1 = new BlockReference(Point3d.Origin, blkTable["1"]))
                using (var blkref2 = new BlockReference(Point3d.Origin, blkTable["2"]))
                        blkref1,
                        blkref2
                    var jig = new DragEntitiesFromOriginJig(blkList);
                        blkref1.TransformBy(jig.Transform);
                        blkref2.TransformBy(jig.Transform);
                tr.Commit();
        class DragEntitiesFromOriginJig : DrawJig
            Point3d dragPoint;
            public Matrix3d Transform { get; private set; }
            public DragEntitiesFromOriginJig(IEnumerable<Entity> ents)
                this.ents = ents;
                var wGeom = draw.Geometry;
                if (wGeom != null)
                    // Update the Transform matrix (displacement from origin to dragPoint)
                    Transform = Matrix3d.Displacement(dragPoint.GetAsVector());
                    wGeom.PushModelTransform(Transform);
                        wGeom.Draw(ent);
                return true;
                var options = new JigPromptPointOptions("\nSpecify destination point: ");
                var ppr = prompts.AcquirePoint(options);
                if (ppr.Value.IsEqualTo(dragPoint))
Gilles Chanteau
GileCAD
GitHub
Message 13 of 17
a.kouchakzadeh
thanks Sir.
I was wondering what happens if we do not dispose blkref? in general, when do we have to dispose some thing?
also, what does blkref1.TransformBy(jig.Transform) do?
Message 14 of 17
_gile
If you do not dispose newly created DBObjects (or any other disposable object) the memory they occupy cannot be freed, and AutoCAD may crash at an unpredictable moment.
That said, we have to disposed any newly created or opened disposable object as soon as possible.
Regarding DBObjects, when we open them with a transaction (transaction.GetObject) or when we add newly created ones to a transaction (transaction.AddNewlyCreatedDBObject) they will be autoamically disposed with the transaction disposing.
In the upper case,  if the jig succeeds (the user specify a point) the newly created block references are added to the transaction and the disposing of the transaction sould take care of disposing them, but if the user cancels the jig, the block references won't be added to the transaction, this is why it's a recommended practice to wrap the 'new BlockReference) expression in a using statement.
Gilles Chanteau
GileCAD
GitHub
Message 15 of 17
_gile
DrawJig uses transient graphics to display the entities jigging, but the block references where insrted at Point3d.Origin, so to reflect the jigging result, we need to displace the block references using the last transformation matrix used in the DrawJig class.
Gilles Chanteau
GileCAD
GitHub
Message 16 of 17
a.kouchakzadeh
in reply to: _gile
nicely explained sir. thank you
Message 17 of 17
kdub_nz
in reply to: _gile
@_gile,
>>> Here's an example inspired your upper one. > . .
very nice !
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
”Boost
