.NET
Iterating trough items in block
8 REPLIES 8
Message 1 of 9
wbdehaan
890 Views, 8 Replies
at multiple places i have drawn the same block in a drawing, and i would like select one block in the drawing, then iterate through the items in the block, and find the actual coordinates of a 3d-polyline (that is drawn in that block) in modelspace. How can I do this?
kind regards,
Wouter de Haan
the Netherlands
8 REPLIES 8
Message 2 of 9
Hallex
in reply to: wbdehaan
Take a look at GetNestedEntity method of Document Editor
What is the language you prefer C# /  VB.NET?
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 9
wbdehaan
in reply to: Hallex
Thanks for your reply,
where can I find the 'document editor' ? I use Visual Studio 2008 (vb.net)
Wouter
Message 4 of 9
Alfred.NESWADBA
for your currentlyy opened DWG:
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MDIActiveDocument.Editor
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 9
Hallex
Here you go, tested on A2009 only
{code}
  Public Shared Function GetAllVertices(ent As Polyline) As Point3dCollection
   Dim points As New Point3dCollection()
   Dim pt As New Point3d()
   Dim i As Integer = 0
   For i = 0 To ent.NumberOfVertices - 1
    pt = ent.GetPoint3dAt(i)
    points.Add(pt)
   Next
   Return points
  End Function
  <CommandMethod("Gnp")> _
  Public Shared Sub TestSubEntity()
   Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
   Dim db As Database = doc.Database
   Dim ed As Editor = doc.Editor
   Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem
   Dim tr As Transaction = db.TransactionManager.StartTransaction()
   Try
    Using tr
     Dim pno As New PromptNestedEntityOptions(vbLf & "Select Nested Polyline >>")
     pno.AllowNone = False
     Dim rs As PromptNestedEntityResult = ed.GetNestedEntity(pno)
     If rs.Status <> PromptStatus.OK Then
      Return
     Dim entId As ObjectId = rs.ObjectId
     Dim selent As Entity = TryCast(tr.GetObject(entId, OpenMode.ForWrite), Entity)
     Dim ids As ObjectId() = rs.GetContainers()
     Dim blkId As ObjectId = ids(0)
     If blkId.IsNull Then
      Return
     Dim blkEnt As Entity = TryCast(tr.GetObject(blkId, OpenMode.ForRead), Entity)
     If blkEnt Is Nothing Then
      Return
     Dim bref As BlockReference = TryCast(blkEnt, BlockReference)
     If bref Is Nothing Then
      Return
     Dim mat As Matrix3d = bref.BlockTransform
     Dim btrec As BlockTableRecord = TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
     Dim pline As Polyline = TryCast(selent, Polyline)
     If pline Is Nothing Then
      Return
     Dim circ As Circle
     Dim points As Point3dCollection = GetAllVertices(pline)
     For i As Integer = 0 To points.Count - 1
      Dim p As Point3d = points(i)
      circ = New Circle(p.TransformBy(mat), Vector3d.ZAxis, 0.1)
      btrec.AppendEntity(circ)
      tr.AddNewlyCreatedDBObject(circ, True)
     Next
     tr.Commit()
    End Using
   Catch ex As Autodesk.AutoCAD.Runtime.Exception
    ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
   Finally
   End Try
  End Sub
{code}
~'J'~
Message 6 of 9
wbdehaan
in reply to: Hallex
Thank you very much for this code, it works!
kind regards
Wouter
Message 7 of 9
Hallex
You're welcome, Wouter
Cheers 🙂
~'J'~
Message 8 of 9
wbdehaan
in reply to: Hallex
In addition, i have another question.
i want to make an adjustment to the supplied code, and therefore i need to step through all objects in the block, but since i am new to .net i cannot get it to work. How can i step through all the objects in the selected block?
Wouter
Message 9 of 9
Hallex
Wouter,
Here ya go
This crappy code of mine is based on Tony Tanzillo's idea that  I did find on this forum
ss give that a try
{code}
 _______________________________________
        <CommandMethod("GAS")> _
        Public Shared Sub GetAllSubentitiesTest()
            Dim sb As New StringBuilder
            Try
                Dim pso As New PromptEntityOptions(vbCr & "Select a Block Reference: ")
                pso.SetRejectMessage(vbLf & " Select  a Block Reference only!")
                pso.AddAllowedClass(GetType(BlockReference), False)
                Dim psr As PromptEntityResult = ed.GetEntity(pso)
                If psr.Status <> PromptStatus.OK Then
                    Return
                Using tr As Transaction = db.TransactionManager.StartTransaction
                    Dim ent As Entity = DirectCast(tr.GetObject(psr.ObjectId, OpenMode.ForRead), Entity)
                    Dim bref As BlockReference = DirectCast(ent, BlockReference)
                        Return
                    Else
                        bref.UpgradeOpen()
                    Dim btr As BlockTableRecord = TryCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead, False), BlockTableRecord)
                    If btr Is Nothing Then
                        Return
                    Dim expIds As New DBObjectCollection
                    bref.Explode(expIds)
                    If expIds.Count > 0 Then
                        For i As Integer = 0 To expIds.Count - 1
                            Dim obj As Entity = TryCast(expIds(i), Entity)
                            If obj IsNot Nothing Then
                                If Not obj.IsWriteEnabled Then
                                    obj.UpgradeOpen()
                                    obj.TransformBy(bref.BlockTransform) '<-- to get right geometric properties
                                sb.AppendLine(String.Format("{0}" + vbTab + "{1}" + vbLf, obj.GetRXClass().Name, obj.GetRXClass().DxfName))
                                obj.Dispose()
                        Next
                    bref.DowngradeOpen()
                End Using
            Catch ex As System.Exception
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbCr & ex.StackTrace)
            Finally
                If sb.ToString <> String.Empty Then
                    MsgBox(sb.ToString)
            End Try
        End Sub
{code}
~'J'~
”Boost
