• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Iterating trough items in block
    296 Views, 8 Replies
    02-16-2012 01:56 AM
    at multiple places i have drawn the same block in a drawing, and i would like select one block in the drawing, then iterate through the items in the block, and find the actual coordinates of a 3d-polyline (that is drawn in that block) in modelspace. How can I do this?
    kind regards,
    Wouter de Haan
    the Netherlands
    Please use plain text.
    Hallex
    Re: Iterating trough items in block
    02-16-2012 02:26 AM in reply to: wbdehaan
    Take a look at GetNestedEntity method of Document Editor
    What is the language you prefer C# /  VB.NET?
    ~'J'~
    Active Contributor
    02-16-2012 03:29 AM in reply to: Hallex
    Thanks for your reply,
    where can I find the 'document editor' ? I use Visual Studio 2008 (vb.net)
    Wouter
    02-16-2012 03:49 AM in reply to: wbdehaan
    for your currentlyy opened DWG:
    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MDIActiveDocument.Editor
    - alfred -
    Alfred NESWADBA
    Hallex
    02-16-2012 06:05 AM in reply to: wbdehaan
    Here you go, tested on A2009 only
    {code}
      Public Shared Function GetAllVertices(ent As Polyline) As Point3dCollection
       Dim points As New Point3dCollection()
       Dim pt As New Point3d()
       Dim i As Integer = 0
       For i = 0 To ent.NumberOfVertices - 1
        pt = ent.GetPoint3dAt(i)
        points.Add(pt)
       Next
       Return points
      End Function
      <CommandMethod("Gnp")> _
      Public Shared Sub TestSubEntity()
       Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
       Dim db As Database = doc.Database
       Dim ed As Editor = doc.Editor
       Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem
       Dim tr As Transaction = db.TransactionManager.StartTransaction()
       Try
        Using tr
         Dim pno As New PromptNestedEntityOptions(vbLf & "Select Nested Polyline >>")
         pno.AllowNone = False
         Dim rs As PromptNestedEntityResult = ed.GetNestedEntity(pno)
         If rs.Status <> PromptStatus.OK Then
          Return
         End If
         Dim entId As ObjectId = rs.ObjectId
         Dim selent As Entity = TryCast(tr.GetObject(entId, OpenMode.ForWrite), Entity)
         Dim ids As ObjectId() = rs.GetContainers()
         Dim blkId As ObjectId = ids(0)
         If blkId.IsNull Then
          Return
         End If
         Dim blkEnt As Entity = TryCast(tr.GetObject(blkId, OpenMode.ForRead), Entity)
         If blkEnt Is Nothing Then
          Return
         End If
         Dim bref As BlockReference = TryCast(blkEnt, BlockReference)
         If bref Is Nothing Then
          Return
         End If
         Dim mat As Matrix3d = bref.BlockTransform
         Dim btrec As BlockTableRecord = TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
         Dim pline As Polyline = TryCast(selent, Polyline)
         If pline Is Nothing Then
          Return
         End If
         Dim circ As Circle
         Dim points As Point3dCollection = GetAllVertices(pline)
         For i As Integer = 0 To points.Count - 1
          Dim p As Point3d = points(i)
          circ = New Circle(p.TransformBy(mat), Vector3d.ZAxis, 0.1)
          btrec.AppendEntity(circ)
          tr.AddNewlyCreatedDBObject(circ, True)
         Next
         tr.Commit()
        End Using
       Catch ex As Autodesk.AutoCAD.Runtime.Exception
        ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
       Finally
       End Try
      End Sub
    {code}
    ~'J'~
    Active Contributor
    02-17-2012 07:18 AM in reply to: Hallex
    Thank you very much for this code, it works!
    kind regards
    Wouter
    Hallex
    02-17-2012 09:45 AM in reply to: wbdehaan
    You're welcome, Wouter
    Cheers :smileyhappy:
    ~'J'~
    Active Contributor
    02-20-2012 01:27 AM in reply to: Hallex
    In addition, i have another question.
    i want to make an adjustment to the supplied code, and therefore i need to step through all objects in the block, but since i am new to .net i cannot get it to work. How can i step through all the objects in the selected block?
    Wouter
    Hallex
    02-20-2012 06:30 AM in reply to: wbdehaan
    Wouter,
    Here ya go
    This crappy code of mine is based on Tony Tanzillo's idea that  I did find on this forum
    ss give that a try
    {code}
     _______________________________________
            <CommandMethod("GAS")> _
            Public Shared Sub GetAllSubentitiesTest()
                Dim sb As New StringBuilder
                Try
                    Dim pso As New PromptEntityOptions(vbCr & "Select a Block Reference: ")
                    pso.SetRejectMessage(vbLf & " Select  a Block Reference only!")
                    pso.AddAllowedClass(GetType(BlockReference), False)
                    Dim psr As PromptEntityResult = ed.GetEntity(pso)
                    If psr.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Using tr As Transaction = db.TransactionManager.StartTransaction
                        Dim ent As Entity = DirectCast(tr.GetObject(psr.ObjectId, OpenMode.ForRead), Entity)
                        Dim bref As BlockReference = DirectCast(ent, BlockReference)
                            Return
                        Else
                            bref.UpgradeOpen()
                        End If
                        Dim btr As BlockTableRecord = TryCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead, False), BlockTableRecord)
                        If btr Is Nothing Then
                            Return
                        End If
                        Dim expIds As New DBObjectCollection
                        bref.Explode(expIds)
                        If expIds.Count > 0 Then
                            For i As Integer = 0 To expIds.Count - 1
                                Dim obj As Entity = TryCast(expIds(i), Entity)
                                If obj IsNot Nothing Then
                                    If Not obj.IsWriteEnabled Then
                                        obj.UpgradeOpen()
                                        obj.TransformBy(bref.BlockTransform) '<-- to get right geometric properties
                                    End If
                                    sb.AppendLine(String.Format("{0}" + vbTab + "{1}" + vbLf, obj.GetRXClass().Name, obj.GetRXClass().DxfName))
                                    obj.Dispose()
                                End If
                            Next
                        End If
                        bref.DowngradeOpen()
                    End Using
                Catch ex As System.Exception
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbCr & ex.StackTrace)
                Finally
                    If sb.ToString <> String.Empty Then
                        MsgBox(sb.ToString)
                    End If
                End Try
            End Sub
    {code}
    ~'J'~
