.NET
Is there a way around late binding if using ActiveX/COM?
1 REPLY 1
281 Views, 1 Reply
Since the ActiveX/COM interface was designed to return array values as Variants (treated as Objects in VB.Net), does that imply that I have not choice, but to use late binding if I want to use any of the returned array values? Is there any other way to get those returned array values without having to use late binding?
Thanks in advance for your help,
Raul
1 REPLY 1
FRFR1426
What's the problem with that? You get the array as an object and you can use it like a regular array (get the bounds, iterate on it...):
Dim attributes = br.GetAttributes()
Console.WriteLine(UBound(attributes)) For Each attributeObj as AcadAttributeReference In attributes Console.WriteLine(attributeObj.TagString) Next
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
”Boost
