Is the Text Window's history available to me as a string? Of course I can send commands to execute, prompt input, and print text. I couldn't see an obvious method or property on the Document object or the Editor object, where I would expect this functionality to be.
I'm trying to capture the text of AutoCAD's "List" command. A given entity's List method doesn't return anything, rather it prints directly to the Text Window.
You can also turn the Logfile on in the Open & Save of the Options dialog, so you can read the whole history from there.
Gaston Nunez
