.NET
Valued Mentor
AubelecBE
Message 1 of 4 (204 Views)
Is possible to disabled de function Save ?
204 Views, 3 Replies
01-17-2013 03:57 AM
Hi all, after a bindXref i save the dwg in a path 'Archive' but if the file already exist i demand the user if i cant erase the dwg in archive before write my dwg. I want to force the user to close the dwg without save if the reponse is 'No'. (The function have BindXref so the dwg do not save this). Is possible ? No save only for this dwg not the other already open (I not know how to use event so.. and my DLL is not loading on the launch of autocad) Thanks
Moderator
Alexander.Rivilis
Message 2 of 4 (200 Views)
Re: Is possible to disabled de function Save ?
01-17-2013 05:01 AM in reply to: AubelecBE
If I understand the question correctly, then:
How to disable the “Save As” dialog
Also you can use Document.PushDbmod() before any changes in dwg-file and Document.PopDbmod() after all changes if "No" is entering.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Mentor
AubelecBE
Message 3 of 4 (179 Views)
01-18-2013 03:29 AM in reply to: Alexander.Rivilis
tanks for reply. I want to disable All Save Command but i dont block Save As.
Moderator
Alexander.Rivilis
Message 4 of 4 (176 Views)
01-18-2013 03:49 AM in reply to: AubelecBE
OK. What about clear system variable DBMOD ? In that case you can continue using command _SAVEAS. Other way is disable/redefine commands _QSAVE, _SAVE
Veto a particular command in AutoCAD
You are not logged in.
Ask the Community
