.NET
Is it possible to remove Embedded VBA Projects?
4 REPLIES 4
fieldguy
1410 Views, 4 Replies
I am working on batch processes and have some files with Embedded VBA Projects. This has spread to several files now because of our work flow - open an old file, save with a new name.  Attached is the dialog that is displayed when the files are opened in the editor.  I would like to "extract" the embedded macros in .NET.  They do not need to be there and they interupt the batch processes.  I know I could un-check the "Always ask before opening projects with macros" but I would rather extract / remove them.
4 REPLIES 4
Jeff_M
in reply to: fieldguy
The embedded macros are held in the Drawing Dictionary "ACAD_VBA". Deleting this dictionary should solve the problem.
Jeff_M, also a frequent Swamper
Hallex
Here is Lisp written by Jeff Mishler
See if that helps to see algorithms
(defun c:rvba (/ adoc cnt dicts)
  (vl-load-com)
  (setq adoc  (vla-get-activedocument
  (vlax-get-acad-object)
 dicts (vla-get-dictionaries adoc)
  (if (not (vl-catch-all-error-p
      (setq vba_dict (vl-catch-all-apply
         (function (lambda ()
       (vla-item dicts "ACAD_VBA")
    (progn
    (setq cnt 0)
    (vlax-for a vba_dict
      (vla-delete a)
      (setq cnt (1+ cnt))
  (alert (strcat "Unloaded " (itoa cnt) " VBA project(s)")))
  (gc)
  (princ)
(c:rvba)
(princ)
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Jeff_M
in reply to: Jeff_M
This seems to work in the limited testing I've done:
    public class testing: IExtensionApplication
        #region IExtensionApplication Members
        public void Initialize()
            Application.DocumentManager.DocumentCreated += new DocumentCollectionEventHandler(DocumentManager_DocumentCreated);
        void DocumentManager_DocumentCreated(object sender, DocumentCollectionEventArgs e)
            using (Transaction tr = e.Document.Database.TransactionManager.StartTransaction())
                DBDictionary nod = (DBDictionary)e.Document.Database.NamedObjectsDictionaryId.GetObject(OpenMode.ForRead);
                try
                    DBDictionary dict = (DBDictionary)tr.GetObject(nod.GetAt("ACAD_VBA"), OpenMode.ForWrite);
                    dict.Erase();
                catch { }
                tr.Commit();
        public void Terminate()
        #endregion
fieldguy
in reply to: Jeff_M
Thank you very much!  Attached is what I am using.
”Boost
