.NET
Valued Contributor
RamanSBV
Message 1 of 2 (275 Views)
Accepted Solution
Is it possible to change the saved xref path without reattaching the xref
275 Views, 1 Replies
08-29-2012 12:49 AM
Please guide me
Raman
BrentBurgess1980
Message 2 of 2 (260 Views)
Re: Is it possible to change the saved xref path without reattaching the xref
08-29-2012 05:26 PM in reply to: RamanSBV
Try this - I haven' tested it yet though.
public static void Repath(Database db, string xrefName, string newPath)
            if (string.IsNullOrEmpty(newPath))
                throw new Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.FileNotFound, "The path can not be found");
            if (!File.Exists(newPath))
                throw new Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.FileNotFound, "The file can not be found");
            BlockTableRecord btr = default(BlockTableRecord);
            using (Transaction tr = db.TransactionManager.StartTransaction())
                XrefGraph DbXrGraph = db.GetHostDwgXrefGraph(true);
                XrefGraphNode XrGraphNode = null;
                XrGraphNode = DbXrGraph.GetXrefNode(xrefName);
                btr = (BlockTableRecord)tr.GetObject(XrGraphNode.BlockTableRecordId, OpenMode.ForWrite);
                btr.PathName = newPath;
                tr.Commit();
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
