IronPython wrapper for AutoCAD.
Message 1 of 1
Has anyone looked into IronPython[1] at all? I'm not much of a C#'er but
from what I understand it should be possible to create a wrapper for
IronPython.Hosting in C# and from there load it as a managed assembly into
AutoCAD. The ultimate intent of this would be the ability to use Python as a
scripting language for AutoCAD.
So far I have been able to evaluate python expressions from the command line
using the code below. However this is a far cry from anything of value, it
was more of a (lame) test.
********************code**********************
using System;
using System.Collections;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using IronPython.Hosting;
namespace PyAcadDotNet
public class AcadInterface
[CommandMethod("pyeval")]
public void pythoneval()
PythonEngine engine = new PythonEngine();
string required = "Enter a python Expression to evaluate:";
CommandLinePrompts.GetString(out required, required, false);
char[] newline = {'\\', 'n'};
string compare = required.TrimEnd(newline);
object results = engine.Evaluate(compare);
CommandLinePrompts.Message(results.ToString());
[CommandMethod("pyfile")]
public void pythonfile(string filename)
//add code here.
********************/code**********************
********************Output*********************
Command: pyeval
Enter a python Expression to evaluate:2+2
4
Command:
********************/Output********************
Does anyone think this project would be feasible or am I just a dreamer?
I'll keep trying to get something going but if anyone is interested in
helping shoot me an email to riltim___@___gmail.com. I have a SubVersion
repository for anyone interesting in coding to use.
[1]
http://www.gotdotnet.com/workspaces/workspace.aspx?id=ad7acff7-ab1e-4bcb-99c0-57ac5a3a9742
Tim Riley
Replies (0)
