.NET
nijhuis
Message 1 of 5 (164 Views)
Invokememberts commands
164 Views, 4 Replies
03-19-2012 01:12 AM
Hello, this code sends an 'Regen' command directly to Autocad. Dim oAcadDoc As Object = Application.DocumentManager.MdiActiveDocument.AcadDocument oAcadDoc.GetType().InvokeMember("Regen", System.Reflection.BindingFlags.InvokeMethod, Nothing, oAcadDoc, New Object() {1}) Does anyone know where i can find wich other commands i can send with invokemember? Is there a list of commands?
Moderator
Alexander.Rivilis
Message 2 of 5 (161 Views)
Re: Invokememberts commands
03-19-2012 01:58 AM in reply to: nijhuis
"Regen" is not a command, but the method of class AcadDocument. List of Objects/Methods/Eventscan be found in AutoCAD Activex and VBA Reference (located in "C:\Program Files\Common Files\Autodesk Shared\acadauto.chm")
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Hallex
Message 3 of 5 (160 Views)
You can't believe it but you might be want to
find all methods / function in VBA editor in
AutoCAD, click Alt+F11 to open VBAIDE in AutoCAD
then see the Help file
~'J'~
nijhuis
Message 4 of 5 (152 Views)
03-19-2012 02:31 AM in reply to: Hallex
Thanks for youre quick reply!!
It is a great help.
Hallex
Message 5 of 5 (142 Views)
03-19-2012 02:54 AM in reply to: nijhuis
You're welcome
Cheers :smileyhappy:
~'J'~
You are not logged in.
Ask the Community
