• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    nijhuis
    Invokememberts commands
    112 Views, 4 Replies
    03-19-2012 01:12 AM
    Hello, this code sends an 'Regen' command directly to Autocad. Dim oAcadDoc As Object = Application.DocumentManager.MdiActiveDocument.AcadDocument oAcadDoc.GetType().InvokeMember("Regen", System.Reflection.BindingFlags.InvokeMethod, Nothing, oAcadDoc, New Object() {1}) Does anyone know where i can find wich other commands i can send with invokemember? Is there a list of commands?
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: Invokememberts commands
    03-19-2012 01:58 AM in reply to: nijhuis
    "Regen" is not a command, but the method of class AcadDocument. List of Objects/Methods/Eventscan be found in AutoCAD Activex and VBA Reference (located in "C:\Program Files\Common Files\Autodesk Shared\acadauto.chm")
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Hallex
    You can't believe it but you might be want to
    find all methods / function in VBA editor in
    AutoCAD, click Alt+F11 to open VBAIDE in AutoCAD
    then see the Help file
    ~'J'~
    nijhuis
    03-19-2012 02:31 AM in reply to: Hallex
    Thanks for youre quick reply!!
    It is a great help.
    Hallex
    03-19-2012 02:54 AM in reply to: nijhuis
    You're welcome
    Cheers :smileyhappy:
    ~'J'~
