.NET
Invalid Execution Context again
1 REPLY 1
GeeHaa
922 Views, 1 Reply
Hi
I am recieving the message invalid execution context when I try to open a drawing. The form that this button is on was opened modeless.
any help would be much appreciated.
 Private Sub BTN_Select_Attribute_Tag_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles BTN_Select_Attribute_Tag.Click
        OpenFileDialog1.Filter = "AutoCAD Drawings|*.dwg"
        OpenFileDialog1.Multiselect = False
        Dim dialogRes As DialogResult = OpenFileDialog1.ShowDialog()
        If dialogRes = Forms.DialogResult.OK Then
            Dim dwgName As String = OpenFileDialog1.FileName
            Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(dwgName, True)
1 REPLY 1
GeeHaa
in reply to: GeeHaa
I think I figured it out.
If I dispose of Openfiledialog1 it opens the drawing without an error.
Thanks Again.
”Boost
