No, the points do not come back in any particular
order. If the intersecting object is a Curve, you
can sort them by their distance from either end
of the curve, using the Curve methods.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5510453@discussion.autodesk.com...
I was wondering if the points returned (more than 1 point) come back in any particular order?
For example:
A line passing thru a block does the point's come back in relation to the line's start and end point or in relation to the block bounding area.
I can build logic to handle the checking of, it is more a point of interest and understanding the intersectwith method
thanks
patrick
