• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Interaction between Winform and Acad
    93 Views, 2 Replies
    10-08-2007 11:34 AM
    Hi:
    I have a winform which I invoke (as a modeless form) from within AutoCad. The User makes a selection in the listbox of the form and clicks on the button. On button click, the form is minimised and the user is prompted to Select a point on the screen upon which a MText and DbText are inserted (text is governed by the list box selection).
    On clicking the form button, I have to click 3 times on the Autocad window to actually do the insertion (even though the selection for a point is prompted at the first click). I would like to transfer control from form to Autocad in 1 click. Below is my code:
    Private Sub cmdInsert_Click(ByVal sender As System.Object, ByVal e _
    As System.EventArgs) Handles cmdInsert.Click
    Dim db As Database = Nothing
    Dim promptPoint As PromptPointOptions = Nothing
    Dim promptResult As PromptPointResult = Nothing
    Dim ptMText As Point3d = Nothing
    Dim ptDText As Point3d = Nothing
    Dim ed As Editor = Nothing
    Try
    Me.TopMost = False
    Me.TopLevel = False
    HostApplicationServices.WorkingDatabase = Autodesk.AutoCAD.ApplicationServices _
    .Application.DocumentManager.MdiActiveDocument.Database
    db = HostApplicationServices.WorkingDatabase
    ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager. _
    MdiActiveDocument.Editor
    'Prompt the user to select the point where the Material Item is to be imported.
    promptPoint = New PromptPointOptions("Select the Insertion Point")
    promptResult = ed.GetPoint(promptPoint)
    If promptResult.Status = PromptStatus.OK Then
    ptMText = promptResult.Value
    'call the function to Create MText.
    CreateMText(ptMText)
    'call the function to Create DText. Calculate the position of the DText relative
    'to the MTexy chosen.
    ptDText = New Point3d(ptMText.X - 0.5625 * db.Dimscale, _
    ptMText.Y - 0.25 * db.Dimscale, 0)
    CreateDText(ptDText)
    _SelectedNode = Nothing
    Autodesk.AutoCAD.ApplicationServices.Application.UpdateScreen()
    Catch ex As Exception
    MessageBox.Show(ex.Message & vbNewLine & ex.StackTrace)
    Finally
    Me.TopMost = True
    Me.TopLevel = True
    db = Nothing
    ed = Nothing
    ptMText = Nothing
    ptDText = Nothing
    End Try
    End Sub
    Please use plain text.
    *Tony Tanzillo
    Re: Interaction between Winform and Acad
    10-08-2007 11:41 AM in reply to: Saumitra
    Don't minimize the form, hide it.
    http://www.caddzone.com
    AcadXTabs: MDI Document Tabs for AutoCAD 2008
    Supporting AutoCAD 2000 through 2008
    http://www.acadxtabs.com
    wrote in message news:5743547@discussion.autodesk.com...
    Hi:
    Try
    Me.TopMost = False
    Me.TopLevel = False
    Finally
    Me.TopMost = True
    Me.TopLevel = True
    db = Nothing
    ed = Nothing
    ptMText = Nothing
    ptDText = Nothing
    End Try
    End Sub
    10-08-2007 11:56 AM in reply to: Saumitra
    Hey Tony,
    That worked. Thanks a lot. I was grappling with this issue for 1 and a half days.
    Saumitra
