.NET
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Instance Forms in several drawings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi All,
I'had just met another matter for my Add-on. I noticed that when I instance a new drawing, while a first one is opened, when I load a new Form, this one keep all first drawing's properties. What could happen?
For example, I would like to add the layer list on a ComboBox.
My source:
Private Sub LayerBox_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
'* Initialisation LayerBox *'
Using acTrans = acCurDb.TransactionManager.StartTransaction()
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead)
For Each acObjId As ObjectId In acLyrTbl
acLyrTblRec = acTrans.GetObject(acObjId, OpenMode.ForRead)
ComboBox1.Items.Add(acLyrTblRec.Name)
Next acObjId
End Using
End SubThis source works, but if i instance a new form on a new drawing, the first drawing's layer list is kept and the new layer list on the second drawing is ignored!
Any ideas?
Re: Instance Forms in several drawings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
then you have to set your variable acCurDb to this other drawing before getting the list of layers.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi alfred,
How can i set my variable acCurDb to each drawing
I set my variables like that (as it's explained on autoCAD Developper's Guide)
Public acDoc As Document = Application.DocumentManager.MdiActiveDocument Public acCurDb As Database = acDoc.Database
Thank You
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
you have the DocumentCollection within the ApplicationServices.Application, that is a list of all opened Documents, run through this list and you have all Documents.
Next step is then to watch events for Opening/Activating/Closing Documents as you have then to update your list.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi alfred,
I've found the source and it works! Thanks you.
In starter Sub just add an Event Argument to detect document activation.
AddHandler Application.DocumentManager.DocumentActivated, AddressOf docColDocAct
End SubThen, when a document is activated the Event Argument refers to docColDocAct which reset acCurDb variable with the current document activated and return it to private Sub LayerBox_Load.
Public Sub docColDocAct(ByVal senderObj As Object, ByVal docColDocActEvtArgs As DocumentCollectionEventArgs)
acCurDb = docColDocActEvtArgs.Document.Database
End Sub
Thank you alfred
